    [Plugin] Spherical Helix (Luxodrome) 1.1
    25 Posts 9 Posters 26.7k Views 9 Watching
      Regular Polygon
      This plugin draws spherical helix, also called a luxodrome. It is a spiral curve on the surface of a sphere, which crosses all meridians of longitude at the same angle. It is another type of spherical spiral, other than the Archimedean spherical spiral I posted a week ago.
      I like to think of it as the path a ship would trace across the globe if it always pointed in the same direction relative to true north. 🤓 The curve below is an example of a course that proceeds slightly north of east, by 5 degrees, at every point.
      M.C. Escher used this curve in his drawing, Sphere Spirals.
      http://www.mcescher.com/Gallery/recogn-bmp/LW428.jpg
      Using a lofting plugin to create a surface between two spirals, and then making 4 copies of the "ribbon", I constructed a crude depiction of Escher’s drawing in SketchUp.
      %(#BF0000)[CHANGE LOG
      *** Version 1.1 - October 7, 2010 ***
      More accurate. Computes the exact values for the points on the curve.]
      The Loxodrome Plugin is at: regularpolygon.org/plugins/loxodrome.php.
      Thanks.
      My SketchUp Plugins
        Beauty of the simplicity! 😎
          Regular Polygon
          Yeah, geometry has its own sort of beauty -- one reason why I prefer graphics programming to web development.
          My SketchUp Plugins
          • MALAISEM Offline
            MALAISE
            Thanks to give us an easy tool for drawing such objects 👍 👍
            MALAISE
              Thanks for the cool plugin.
              http://farm5.static.flickr.com/4105/4975937366_175f0bfcae.jpg
              • shuraS Offline
                shura
                Woohoo! Just love your plugins Mr. Polygon, thanks a lot!
                • boofredlayB Offline
                  boofredlay
                  Thanks for this.
                    It's kind of fun with Proper Animation. 😄
                      boofredlay
                      That is cool Dave. How did you do it?
                        Hi Eric,
                        Thank you.
                        I made a spherical helix, copy, rotated it 60 degrees (I think) and used Chris's Simple Loft to make the ribbon which I copy/rotated to make the other two. Then I set up a pair of scenes and used Proper Animation to get a start and end position. the difference between the two positions is that the ribbons were rotated 180°. The funny thing is that when I switched from scene to scene, I got what you see. I was kind of expecting something like a barber pole but this was cooler.
                        I made a video screen grab with Snagit and an animated GIF in VirtualDub.
                          Soon Christmas 😎
                            Soon Christmas 😎
                            I was thinking exactly the same thing. 😄
                            • simon le bonS Offline
                              simon le bon
                              Dear Dave,
                              First I have no idea with the process you have used to produce this rendered luxodrome
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/th_4975937366_175f0bfcae.jpg
                              But I like it very much.
                              secondly,
                              have you really used Chris's Simple Loft to make the ribbon? As far as I Know about it we can't skin two joining curves with it!! If there is a way, please be kind to report it.
                              Dear Regular Polygon,
                              thank you for this new plugin. I have I think bookmarked each of them.
                              ++simonlebon
                                Simon,
                                In both cases I used Simple Loft and set the number of segments to 1. The ends of the helices are trimmed off so they are close to in alignment. They actually don't touch each other. It does seem like a long wait for the plugin once you start it but you just wait a little bit and it creates the skin just fine. Your super computer may be much faster than my old dinosaur.
                                As far as rendering the first one, I used some sketchy line style and rough paper texture style I have (can't remember which) and then exported a JPG. I added some grain, haze and the purplish gradient in Picasa.
                                  mequan
                                  I don't download!!! Why????
                                    The link at the bottom of the original post should take you to Regular Polygon's blog from which you should be able download the plugin.
                                      http://img.photobucket.com/albums/v506/weekender410/Spin2.gif
                                      More playing. I should be doing work.
                                        Regular Polygon
                                        A spherical barber pole! That looks great, Dave. 👍 😄
                                        My SketchUp Plugins
                                          simon le bon
                                          @dave r said:
                                          Simon,
                                          In both cases I used Simple Loft.../
                                          .../I added some grain, haze and the purplish gradient in Picasa.
                                          Clever & Simple as usual dear Dave. Thanks a lot 😉 , simon.
                                            Regular Polygon
                                            Update to Version 1.1.
                                            The original version used an approximation to compute the points on the curve -- unfortunately, I couldn't solve the math for the exact equations. 😳 Since then, I came across the equations that do compute the exact values for the coordinates of each point. They are implemented in Version 1.1.
                                            The difference in the spherical helix between the two versions is not really noticeable. But, if you are doing something that requires accuracy, then it might be worth downloading this latest version.
                                            My SketchUp Plugins
                                            • 1 / 2
