    Export animation with style
    4 Posts 2 Posters 525 Views 2 Watching
      Jorgensen
      I'm trying to create some animation by exporting animation as images and then create a movie via virtualdub.
      But it seems that one can't export movies with a custom style - is this right ? or am I doing something wrong ?
      Bo Jorgensen
      sketchup pro 2016 16.1.1449 64 bit | windows 10 pro | i7-3770k @3.5 GHz | 16gb ram | gtx 780 ti / gtx 980 ti | nvidia driver 368.39
      • PixeroP Offline
        Pixero
        Yes it is doable with a technique where you have a scene for every frame of the animation.
        Then use my script "change transition times" (at the bottom of this post: http://forums.sketchucation.com/viewtopic.php?f=323&t=20173&p=167962#p167962 )
        to set the transition times between the scenes to a value corresponding your wanted framerate. Then when you export the animation use that same framerate and it will use each scene as one frame.
        It works. Here's a proof of concept.
        http://www.pixero.com/stuff/styles_anim.gif
          Jorgensen
          Hi Pixero
          Thanks for your reply. I'm sure going to try this.
          Regarding one scene for every frame - is the an easy way to create this, when I have one scene for start and one for the end ?
          Bo Jorgensen
          • PixeroP Offline
            Pixero
            @jorgensen said:
            Regarding one scene for every frame - is there an easy way to create this, when I have one scene for start and one for the end ?
            If you read my whole post in the link above there is a way I developed that uses a curve with segments (vertices) for each frame. It works, but is not very intuitive.
            Soon there will be a better way... πŸ˜‰
