    Transparent PNGs
    5 Posts 2 Posters 489 Views 2 Watching
    • JoelM3DMJ Offline
      JoelM3DM
      A couple versions ago, I tried to insert a PNG image with a transparent background into an SU model with stylized lines. Problems! The PNG was not fully transparent and the line style did not show thru the background. This was a bug in SU and needed a workaround of using an image that without a background.
      Has this been fixed in version 8? Or does anyone know of another (simpler) workaround?
           - Joel
      || Joel Metzger 3D Modeling
      || story-shorts.net - Animation with SU
      • honoluludesktopH Offline
        honoluludesktop
        Here is a png with a alpha background.
        • JoelM3DMJ Offline
          JoelM3DM
          Yes, it is simple to create a transparent alpha background. but look what happens when you put it over a line style. The alpha is transparent to the lines but NOT to the line style. This is a bug in SU, as far as I can see.
            honoluludesktop
            Bug or feature ?-) Not making fun, just that I got my own problems 😞
            • JoelM3DMJ Offline
              JoelM3DM
              Yes, with a tree image the transparency is a feature, but if the image is person or solid object, then there's a problem. The lines in the distance show through that person when transparency is enabled. Or the background blocks the styles, if transparency is disabled.
                    - Joel
