    Question about pages
    6 Posts 3 Posters 475 Views 3 Watching
    • K Offline
      ktkoh
      working on new plugin and I need to check the Text name of each existing page and this code does not work or give an error message. How should it be written?
      model = Sketchup.active_model
      selection = model.selection
      pages = model.pages
      pages.each {|name= page.name| UI.messagebox name}
      Thanks Keith
      • K Offline
        ktkoh
        I found the solution to the page name question.
        # Add page named Assembly if not already added
              pagename=[]
              pgAssy = "no"
        	    pages.each {|p|
              pagename = p.name
              if pagename == "Assembly"
                pgAssy = "yes"
              end }#if and each loop
              if pgAssy == "no"
                pages.add "Assembly"
              end#if
        thanks for looking
        Keith
          Jim
          That looks like it will work, ktkoh. You could also have done this:
          pages = Sketchup.active_model.pages
          if (pages["Assembly"].nil?)
              pages.add("Assembly")
          Because when you try to retrieve a Page which does not exists, you get nil.
            Also, string comparisons are slow. Instead of "yes"/ "no" it's better to use true or false.
              Jim
              By the way, what is the difference between a page .name and a page .label?
                Seem to be the same, except label doesn't have a setter...
                The examples for the getters are pretty much the same.
