    Rendering_options, "back edges"
    11 Posts 5 Posters 3.5k Views 5 Watching
    • daikuD Offline
      daiku
      How do you dump out the list of rendering options? I'm looking for the parameter for the new "back edges" edge style in SU8. CB.
      Clark Bremer
      http://www.northernlightstimberframing.com
        Sketchup.active_model.rendering_options.each_pair do |k,v|; puts "#{k}=#{v}"; end
        BackgroundColor=Color(204, 204, 201, 255) BandColor=Color( 0, 0, 0, 127) ConstructionColor=Color( 0, 0, 0, 255) DepthQueWidth=4 DisplayColorByLayer=false DisplayDims=true DisplayFog=false DisplayInstanceAxes=false DisplaySketchAxes=true DisplayText=true DisplayWatermarks=true DrawDepthQue=false DrawGround=false DrawHidden=false DrawHorizon=true DrawLineEnds=true DrawProfilesOnly=false DrawSilhouettes=true DrawUnderground=true EdgeColorMode=1 EdgeDisplayMode=1 EdgeType=0 ExtendLines=true FaceBackColor=Color(164, 178, 187, 255) FaceColorMode=0 FaceFrontColor=Color(255, 255, 255, 255) FogColor=Color(204, 204, 201, 255) FogEndDist=-1.0 FogStartDist=-1.0 FogUseBkColor=true ForegroundColor=Color( 0, 0, 0, 255) GroundColor=Color(210, 208, 185, 255) GroundTransparency=50 HideConstructionGeometry=false HighlightColor=Color( 0, 1, 255, 255) HorizonColor=Color( 0, 0, 0, 0) InactiveFade=0.25 InactiveHidden=false InstanceFade=0.5 InstanceHidden=false JitterEdges=false LineEndWidth=7 LineExtension=2 LockedColor=Color(255, 0, 0, 255) MaterialTransparency=true ModelTransparency=false RenderMode=2 SectionActiveColor=Color(255, 135, 0, 255) SectionCutWidth=3 SectionDefaultCutColor=Color( 0, 0, 0, 255) SectionInactiveColor=Color(112, 105, 97, 255) ShowViewName=true SilhouetteWidth=2 SkyColor=Color(198, 205, 208, 255) Texture=true TransparencySort=0
        • daikuD Offline
          daiku
          Thanks. I can't see any differences between when "back edges" is turned on or off. CB.
          Clark Bremer
          • demD Offline
            dem
            I`m searching name of rendering option
            • Dan RathbunD Offline
              Dan Rathbun
              You are correct. I filed a beta bug report, and Simone logged it as internal bug 2916316.
              Additional comments, and ideas I posted:
              OK.. I looked at this a bit further, and my conculsion is that...
              RenderingOptions[’EdgeDisplayMode’] needs to be updated.
              The setting is tied to Edges
              Currently the value of the RenderingOptions[’EdgeDisplayMode’] key is 0 when both are turned off.
              Toggling Edges ON adds 1 to the value. (BUT.. if BackEdges is ON, and you turn Edges OFF, the value remains at 1.)
              We need toggling BackEdges ON to add 2 to the value, so that:
              RenderingOptions[’EdgeDisplayMode’] :
              0 = both OFF
              1 = Edges ON && BackEdges OFF
              2 = Edges OFF && BackEdges ON
              This may not be used (rendered,) meaning that mode 3 would be enforced, but we should still be able to test for mode setting 2 (the state of checkboxes in the Styles dialog, and the menu item check states.)
              3 = both ON
              I'm not here much anymore.
              • demD Offline
                dem
                thanks, but
                in ruby console
                Sketchup.active_model.rendering_options["EdgeDisplayMode"] =
                works only 1 and 2
                Sketchup pro 8.0.3117
                  Dan Rathbun
                  @dem said:
                  thanks, but
                  in ruby console
                  works only 1 and 2
                  It should only have 0 and 1 values at this time.
                  You did not read what I said correctly. I am proposing that values 2 and 3 be added to the API so that we can know the BackEdges setting.
                  • demD Offline
                    dem
                    Sorry, i mind 0 and 1..
                    And how can I add it to API? 😃
                    ps. my English is not good
                      Dan Rathbun
                      You CANNOT.
                      Google must do it on the C++ side of the application code.
                      That is why I filed the Bug Report, and a number was assigned to it, by the Sketchup Development Team.
                        TBoy
                        Any updated info for this topic?
                          Dan Rathbun
                          YES. (5 years after this thread ...)
                          In the SketchUp 2015 release, a new key was added to the RenderingOptions hash:
                          The key is: "DrawBackEdges"
                          See API documentation:
                          http://ruby.sketchup.com/Sketchup/RenderingOptions.html
