    Rendering_options, "back edges"
    11 Posts 5 Posters 3.8k Views 5 Watching
    • daikuD
      daiku
      How do you dump out the list of rendering options? I'm looking for the parameter for the new "back edges" edge style in SU8. CB.
      Clark Bremer
      http://www.northernlightstimberframing.com
        Sketchup.active_model.rendering_options.each_pair do |k,v|; puts "#{k}=#{v}"; end
        BackgroundColor=Color(204, 204, 201, 255) BandColor=Color( 0, 0, 0, 127) ConstructionColor=Color( 0, 0, 0, 255) DepthQueWidth=4 DisplayColorByLayer=false DisplayDims=true DisplayFog=false DisplayInstanceAxes=false DisplaySketchAxes=true DisplayText=true DisplayWatermarks=true DrawDepthQue=false DrawGround=false DrawHidden=false DrawHorizon=true DrawLineEnds=true DrawProfilesOnly=false DrawSilhouettes=true DrawUnderground=true EdgeColorMode=1 EdgeDisplayMode=1 EdgeType=0 ExtendLines=true FaceBackColor=Color(164, 178, 187, 255) FaceColorMode=0 FaceFrontColor=Color(255, 255, 255, 255) FogColor=Color(204, 204, 201, 255) FogEndDist=-1.0 FogStartDist=-1.0 FogUseBkColor=true ForegroundColor=Color( 0, 0, 0, 255) GroundColor=Color(210, 208, 185, 255) GroundTransparency=50 HideConstructionGeometry=false HighlightColor=Color( 0, 1, 255, 255) HorizonColor=Color( 0, 0, 0, 0) InactiveFade=0.25 InactiveHidden=false InstanceFade=0.5 InstanceHidden=false JitterEdges=false LineEndWidth=7 LineExtension=2 LockedColor=Color(255, 0, 0, 255) MaterialTransparency=true ModelTransparency=false RenderMode=2 SectionActiveColor=Color(255, 135, 0, 255) SectionCutWidth=3 SectionDefaultCutColor=Color( 0, 0, 0, 255) SectionInactiveColor=Color(112, 105, 97, 255) ShowViewName=true SilhouetteWidth=2 SkyColor=Color(198, 205, 208, 255) Texture=true TransparencySort=0
        • daikuD
          daiku
          Thanks. I can't see any differences between when "back edges" is turned on or off. CB.
          Clark Bremer
          • demD
            dem
            I`m searching name of rendering option
            • Dan RathbunD
              Dan Rathbun
              You are correct. I filed a beta bug report, and Simone logged it as internal bug 2916316.
              Additional comments, and ideas I posted:
              OK.. I looked at this a bit further, and my conculsion is that...
              RenderingOptions[’EdgeDisplayMode’] needs to be updated.
              The setting is tied to Edges
              Currently the value of the RenderingOptions[’EdgeDisplayMode’] key is 0 when both are turned off.
              Toggling Edges ON adds 1 to the value. (BUT.. if BackEdges is ON, and you turn Edges OFF, the value remains at 1.)
              We need toggling BackEdges ON to add 2 to the value, so that:
              RenderingOptions[’EdgeDisplayMode’] :
              0 = both OFF
              1 = Edges ON && BackEdges OFF
              2 = Edges OFF && BackEdges ON
              This may not be used (rendered,) meaning that mode 3 would be enforced, but we should still be able to test for mode setting 2 (the state of checkboxes in the Styles dialog, and the menu item check states.)
              3 = both ON
              I'm not here much anymore.
              • demD
                dem
                thanks, but
                in ruby console
                Sketchup.active_model.rendering_options["EdgeDisplayMode"] =
                works only 1 and 2
                Sketchup pro 8.0.3117
                • Dan RathbunD
                  Dan Rathbun
                  @dem said:
                  thanks, but
                  in ruby console
                  works only 1 and 2
                  It should only have 0 and 1 values at this time.
                  You did not read what I said correctly. I am proposing that values 2 and 3 be added to the API so that we can know the BackEdges setting.
                  • demD
                    dem
                    Sorry, i mind 0 and 1..
                    And how can I add it to API? 😃
                    ps. my English is not good
                    • Dan RathbunD
                      Dan Rathbun
                      You CANNOT.
                      Google must do it on the C++ side of the application code.
                      That is why I filed the Bug Report, and a number was assigned to it, by the Sketchup Development Team.
                      • T
                        TBoy
                        Any updated info for this topic?
                        • Dan RathbunD
                          Dan Rathbun
                          YES. (5 years after this thread ...)
                          In the SketchUp 2015 release, a new key was added to the RenderingOptions hash:
                          The key is: "DrawBackEdges"
                          See API documentation:
                          http://ruby.sketchup.com/Sketchup/RenderingOptions.html
