    UI.openpanel - wildcard bug
    7 Posts 5 Posters 1.1k Views 5 Watching
    • thomthomT
      http://code.google.com/apis/sketchup/docs/ourdoc/ui.html#openpanel
      SU7 Bug: The wildcards are not working properly if more than one is entered (e.g. ".jpg;.png") or if a directory is included. The '*' gets converted to a '_'.
      I get that bug even with only one wildcard:
      filename = UI.openpanel('Open CSV File', 'c:\\', '*.csv')
      • Dan RathbunD
        Dan Rathbun
        I always got that bug... with any wildcard, including '?'
        And BTW I did file a new bug report on this, as a reminder.
        I'm not here much anymore.
        • fredo6F
          fredo6
          Dan, Tom,
          Thans for having filed the bug to the SU Team.
          Apparently this is still not solved in SU8 M1
          Note that, strangely, wildcards work in SU6, but in SU7 and SU8, we got the * replaced by an underscore
          Fredo
          • thomthomT
            Yea - It's an annoying regression bug. Seems like it's not been considered important enough. Though I find it troublesome as it#s makes it awkward for the end user. πŸ˜•
            • S
              shirazbj
              I tried "a.jpg".
              Why ".jpg" is not listed in the "files of type"?
              • honoluludesktopH
                honoluludesktop
                Someone previously showed me that it works this way.
                chosen_file=UI.openpanel("Select DXF File","", "*.Dxf")
                • Dan RathbunD
                  Dan Rathbun
                  And also like:
                  chosen_file=UI.openpanel("Select DXF File","*.Dxf")
                  However... Windows will use it's own directory paths it automatically saves into the Registry, for each file extension.
                  (1) If the openpanel has never before selected a *.dxf file, then the openpanel will (likely) open in the user's My Documents folder.
                  (2) If the User did previously select a *.dxf file, with the openpanel, Windows will open in the Most Recently Used (MRU) path Windows saved for the *.dxf extention.
                  Setting the working directory via Dir.chdir has no effect on what directory the openpanel starts in.
