    [Plugin] Axes Tools
    63 Posts 20 Posters 88.8k Views 20 Watching
      Overview
      Two methods I wrote to reset the axis of components to their bounding box' centre.
      Useful for them pesky DWG imports where the insertion point of the blocks are really far away, causing the components to jitter.
      Access
      Plugins > Axes Tools
      Features
      • Set Insertion Point
      Requirements
      • SketchUp 7 or newer - ( Other versions untested )
      • TT_Lib2 (v2.2.0)
      SketchUp Plugins | PluginStore | SketchUcation
      SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
      (sketchucation.com)
      Footprint
      http://forums.sketchucation.com/download/file.php?id=53762
      <Sketchup>/Plugins/
      http://forums.sketchucation.com/download/file.php?id=53763
      tt_axes.rb
      http://forums.sketchucation.com/download/file.php?id=53761
        Ben Ritter
        Thomas, you are so generous. β˜€
          Ben Ritter
          What happened to SU8 all of a sudden. Left in the dust.
            Just given a steroid boost. πŸ˜‰
              Guiness book record for number of plugins by day is crushed! πŸ˜„
                rv1974
                Hi Thom!
                Could your make your genious tool even more genious?:
                1. Axes to the component's bottomcenter;
                2. Add CPoint at pivot (there's no snap to pivot in SU unfortunatly)
                  @rv1974 said:
                  1. Axes to the component's bottom center;
                  Yup, on the todo list to be able to choose which part of the boundingbox.
                  @rv1974 said:
                  1. Add CPoint at pivot (there's no snap to pivot in SU unfortunatly)
                  Can do that, yes. But I'll add it to Guide Tools.
                    rv1974
                    1.Fine but could bottom center be default value? Or at least make script to remember last preference.
                    2.Wouldn't it be smarter not split into 2 commands?
                    P.S. Not concerned to the topic:
                    You made some nice ruby 'groups to components'. But After the procedure it deselects the new born component. Could it keep the selection on?
                      It'd remember the last used setting.
                      It'd not be between center or bottom center, it's be between any corner, and center of each of the bounding box sides. So it'd be a lot more options than just two.
                      http://forums.sketchucation.com/viewtopic.php?f=323&t=29462 ?
                      Yea - easy enough.
                        rv1974
                        It'd not be between center or bottom center, it's be between any corner, and center of each of the bounding box sides. So it'd be a lot more options than just two.[/quote]
                        I'm afraid I don't unerstand you. Anyhow what I mean is moving pivot to bottom center + placing cpoint
                        to the same bottom center within one ruby (command) would be better.
                          Some may not want to add a cpoint and some may not want to adjust the axis. Keep them separated and people can choose.
                            rv1974
                            You decide (though I see a bunch of rubies that do insert here and there cpoints without too much''people"
                            protest). The main thing for me that cpoint at pivot would be a part of given component.
                              Ah - I can see uses for inside and outside.
                              Will make a note of that.
                                Added CPoint at Insertion Point to Guide Tools: http://forums.sketchucation.com/viewtopic.php?f=323&t=30506
                                  Version 1.1.0
                                  • Requires TT_Lib2 (v2.2.0)
                                  • Replaced the old menus with Set Insertion Point
                                    rv1974
                                    I wish you were SU product manager it'd be entirely different world.
                                      rv1974
                                      One more thing:
                                      Could this script stick to the current model axes not absolute world?
                                        @rv1974 said:
                                        One more thing:
                                        It doesn't rotate the axis, it simply moves the origin of the components - the insertion point.
                                        Though, it could be made to also rotate the axis to match the current model axis.
                                          rv1974
                                          That's exactly what I meant
                                            diegog321
                                            thank you thom
                                            This plugin saved my life about five minutes ago!
                                            Diego
                                            • 1 / 4
