    [Plugin] Axes Tools
    63 Posts 20 Posters 90.5k Views 20 Watching
      @rv1974 said:
      1. Axes to the component's bottom center;
      Yup, on the todo list to be able to choose which part of the boundingbox.
      @rv1974 said:
      1. Add CPoint at pivot (there's no snap to pivot in SU unfortunatly)
      Can do that, yes. But I'll add it to Guide Tools.
        rv1974
        1.Fine but could bottom center be default value? Or at least make script to remember last preference.
        2.Wouldn't it be smarter not split into 2 commands?
        P.S. Not concerned to the topic:
        You made some nice ruby 'groups to components'. But After the procedure it deselects the new born component. Could it keep the selection on?
          It'd remember the last used setting.
          It'd not be between center or bottom center, it's be between any corner, and center of each of the bounding box sides. So it'd be a lot more options than just two.
          http://forums.sketchucation.com/viewtopic.php?f=323&t=29462 ?
          Yea - easy enough.
            rv1974
            It'd not be between center or bottom center, it's be between any corner, and center of each of the bounding box sides. So it'd be a lot more options than just two.[/quote]
            I'm afraid I don't unerstand you. Anyhow what I mean is moving pivot to bottom center + placing cpoint
            to the same bottom center within one ruby (command) would be better.
              Some may not want to add a cpoint and some may not want to adjust the axis. Keep them separated and people can choose.
                rv1974
                You decide (though I see a bunch of rubies that do insert here and there cpoints without too much''people"
                protest). The main thing for me that cpoint at pivot would be a part of given component.
                  Ah - I can see uses for inside and outside.
                  Will make a note of that.
                    Added CPoint at Insertion Point to Guide Tools: http://forums.sketchucation.com/viewtopic.php?f=323&t=30506
                      Version 1.1.0
                      • Requires TT_Lib2 (v2.2.0)
                      • Replaced the old menus with Set Insertion Point
                        rv1974
                        I wish you were SU product manager it'd be entirely different world.
                          rv1974
                          One more thing:
                          Could this script stick to the current model axes not absolute world?
                            @rv1974 said:
                            One more thing:
                            It doesn't rotate the axis, it simply moves the origin of the components - the insertion point.
                            Though, it could be made to also rotate the axis to match the current model axis.
                              rv1974
                              That's exactly what I meant
                                diegog321
                                thank you thom
                                This plugin saved my life about five minutes ago!
                                Diego
                                  daniel266
                                  OHH my GOD !! GEnius i have a dwg file that moves all along the place and i need to explode to make it stop this just solved everything!!
                                  SO much THX!
                                    Ruturaj
                                    Hello sir,
                                    This plugin is very good & handful .....
                                    but when i was applying following Settings :
                                    X (Red) : Right
                                    y (Green): Back
                                    z (Blue): Top
                                    selected any group or component its work
                                    but when i was applying again it on another group or component, it will not reset to the default settings ....?
                                    I was changing default MODULE
                                    ### MODULE VARIABLES ### -------------------------------------------------
                                    	# Preference
                                    	@settings = TT;;Settings.new('Axes editor tool')
                                    	@settings[;x, 'Left']
                                    	@settings[;y, 'Front']
                                    	@settings[;z, 'Bottom']
                                    How to reset ......?
                                    Thank you,
                                    Ruturaj
                                    Thanks,
                                    RuturaJ
                                      I remembers the last values you used. Just select what you want from the drop down menus. The "defaults" you refer to is only defaults for the very first time the plugin runs.
                                        Ruturaj
                                        oh......... ok..... 👍
                                        Thanks,
                                        RuturaJ
                                        • utilerU Offline
                                          utiler
                                          Hey Thomas, love this little gem.....! So simple yet so powerful!
                                          I have a question.
                                          See the attached images of a plan view:
                                          And a perspective view:
                                          Say I want to set my axis to the rear of the couch, centered and at the bottom. When I followed your axis tool to achieve this I have to input these settings:
                                          Instead of 'X' back, 'Y' centre', 'Z' bottom.
                                          It appears that the options in the dialogue box should be reversed. Don't you think that the 'X' options should be Front/Centre/Right and 'Y' options should be Left/Centre/Right instead of the other way around? It would just make sense according to how you view a model after all from an axis green is naturally north/south or vertical on the page or screen and red is east /west or horizontal......
                                          Love your work!!
                                          PS: Skippy attached FYI.
                                          couch.skp
                                          Just Curious...
                                            utiler: Front/Back, Left/Right, Top/Bottom is determined by the components internal axis - not the model axis.
                                            note that this plugin does not change the orientation of the component axis, but just the axis origin.
                                            • 1 / 4
