    [Plugin] TT_Lib²
    310 Posts 66 Posters 419.0k Views 66 Watching
      Overview
      This is not a standalone plugin. It is only needed by some plugins.
      Documentation
      http://www.thomthom.net/software/sketchup/tt_lib2/doc/TT.html
      Remove older TT_Lib² versions if you already have TT_Lib² installed.
      Guide: How to install RBZ Files
      SketchUp Plugins | PluginStore | SketchUcation
      SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
      (sketchucation.com)
        Version 2.1.0
        • Added module: TT::UVQ
        • Added class: TT::UV_Plane
        • Added method: TT::Entities.bounds
        • Added class: TT::Gizmo::Manipulator
        • Added module: TT::Selection
        • Fixed: Ray.test
        • JClementsJ Offline
          JClements
          Thomas, we missed you at the Basecamp. Many people asked about you. Hopefully, there can be Europe Basecamp in the future for the loyal people on the other side of the Atlantic.
          Regard, John
            Thanks John - I really wished I could have been there.
            Been fun to see some of the pictures, the faces behinds the nicknames. Looking forward to more and hopefully video from the talks.
              Version 2.1.1
              • Fixed bug: Ray.test (Workaround for SU8.0 bug)
              • EscapeArtistE Offline
                EscapeArtist
                Thanks!
                  Version 2.2.0
                  • Added module: TT::Bounds
                    Version 2.3.0
                    • Added method: TT::Geom3d.spiral_sphere
                    • Fixed: TT::Ray.test
                      Version 2.4.0
                      • Added module: TT::Binary
                      • Added class: TT::JSON
                      • Added module: TT::GUI
                      • Added class: TT::Window
                      • Added class: TT::Inputbox
                      • Added module: TT::System
                      • Added module: TT::Locale
                      • Added module: TT::Cursor
                        bestmate
                        Great job you do here Thomas, i do not how you find the a time ( amazing)
                        I have the select curve tool and i have TT_lib in one folder,TT_lib selectcurve in another and in that in its own folder TT_lib2 and tt_select_curve on its own in the plug in folder with all the above . (that was complicated) i get a message cannot find ? could you help me please my fine friend ( ps great glasses) regards Phil
                          Maybe when you unzipp the file you have one path folder more
                          TT_Lib2-2.4.0) / TT_Lib2 /...
                          It was my case ! 😳
                          At any time I forget to keep only TT_Lib2/... !!! 😳 😳 😳
                          TT_Lib2-2.4.0 must be not taken because that make one path folder more 😒
                          And after with only in Plugins folder TT_Lib2/... all works fine 😎
                          That what i want and all works fine!
                          I Select all then Plugins/ Thomthom Plugins/Guide Tools/ CPoint at Arc Center and all points are drawn! ☀
                          Bravo ThomThom! 👍 (works fine in the V6)
                          http://forums.sketchucation.com/download/file.php?id=55871
                            hm.. didn't notice this message until now.
                            As Pilou said, check that you have file files in the correct location. At the bottom of each page for them plugins there is an example of their footprint in the Plugins folder.
                              Hello Thomthom
                              Someone say thank you 😄
                                Hello Thomthom
                                • PixeroP Offline
                                  Pixero
                                  I'm getting this error when starting SU.
                                  I have the latest version ov Selection Toys along with TT_Lib version 1 and 2.4.0.
                                  SU 7.1 Windows.
                                    SelectionToys does not use TT_Lib2 at all.
                                    You need to ensure you have the correction version of TT_Lib (1.x) and that it's installed correctly.
                                    • PixeroP Offline
                                      Pixero
                                      Reinstalling the latest 1.x version helped.
                                      By the way I'm tired of rearrangeing my toolbars once again. How does the save toolbar in SU8 work?
                                        Poorly.
                                        View->Toolbars->Save Positions
                                        View->Toolbars->Restore Positions
                                        I've found it to not work so well when adding/removing plugins with toolbars...
                                          Jim
                                          Thom, have you generated docs for this lib? I appreciate that you are thinking in terms of re-use, and your code is clean and clear. Is this licensed so that other people can use it also?
                                            I have some docs generated. But the comments are not complete. It's still taking shape and some things will be changed.
                                            I'll try to make a note on the modules that are WIP and include more examples. If you have questions about particulars just let me know and I can push them up on the update list.
                                            For the brave, here is the current output: http://www.thomthom.net/software/sketchup/tt_lib2/doc/ (for TT_Lib 2.5 mind you)
                                            (Anyone knows how to modify YARDs templates so the constant lists will be more compact?)
                                            • 15
                                            • 16
                                            • 1 / 16
