    [Plugin] TT_Lib²
    310 Posts 66 Posters 486.2k Views 66 Watching
      Version 2.4.0
      • Added module: TT::Binary
      • Added class: TT::JSON
      • Added module: TT::GUI
      • Added class: TT::Window
      • Added class: TT::Inputbox
      • Added module: TT::System
      • Added module: TT::Locale
      • Added module: TT::Cursor
      • B
        bestmate
        Great job you do here Thomas, i do not how you find the a time ( amazing)
        I have the select curve tool and i have TT_lib in one folder,TT_lib selectcurve in another and in that in its own folder TT_lib2 and tt_select_curve on its own in the plug in folder with all the above . (that was complicated) i get a message cannot find ? could you help me please my fine friend ( ps great glasses) regards Phil
          Maybe when you unzipp the file you have one path folder more
          TT_Lib2-2.4.0) / TT_Lib2 /...
          It was my case ! 😳
          At any time I forget to keep only TT_Lib2/... !!! 😳 😳 😳
          TT_Lib2-2.4.0 must be not taken because that make one path folder more 😒
          And after with only in Plugins folder TT_Lib2/... all works fine 😎
          That what i want and all works fine!
          I Select all then Plugins/ Thomthom Plugins/Guide Tools/ CPoint at Arc Center and all points are drawn! ☀
          Bravo ThomThom! 👍 (works fine in the V6)
          http://forums.sketchucation.com/download/file.php?id=55871
            hm.. didn't notice this message until now.
            As Pilou said, check that you have file files in the correct location. At the bottom of each page for them plugins there is an example of their footprint in the Plugins folder.
              Hello Thomthom
              Someone say thank you 😄
                Hello Thomthom
                • PixeroP
                  Pixero
                  I'm getting this error when starting SU.
                  I have the latest version ov Selection Toys along with TT_Lib version 1 and 2.4.0.
                  SU 7.1 Windows.
                    SelectionToys does not use TT_Lib2 at all.
                    You need to ensure you have the correction version of TT_Lib (1.x) and that it's installed correctly.
                    • PixeroP
                      Pixero
                      Reinstalling the latest 1.x version helped.
                      By the way I'm tired of rearrangeing my toolbars once again. How does the save toolbar in SU8 work?
                        Poorly.
                        View->Toolbars->Save Positions
                        View->Toolbars->Restore Positions
                        I've found it to not work so well when adding/removing plugins with toolbars...
                          Jim
                          Thom, have you generated docs for this lib? I appreciate that you are thinking in terms of re-use, and your code is clean and clear. Is this licensed so that other people can use it also?
                            I have some docs generated. But the comments are not complete. It's still taking shape and some things will be changed.
                            I'll try to make a note on the modules that are WIP and include more examples. If you have questions about particulars just let me know and I can push them up on the update list.
                            For the brave, here is the current output: http://www.thomthom.net/software/sketchup/tt_lib2/doc/ (for TT_Lib 2.5 mind you)
                            (Anyone knows how to modify YARDs templates so the constant lists will be more compact?)
                              Jim
                              Guess I could run yard myself... heh.
                                Just a preview of one of the GUI gizmos I'm working on.
                                [flash=640,385:378bq4x9]http://www.youtube.com/v/hA0H_Txfjd4?fs=1&hl=en_US[/flash:378bq4x9]
                                Code to generate the windows:
                                # Compatible; SketchUp 7 (PC)
                                #             (other versions untested)
                                # Thomas Thomassen
                                # thomas[at]thomthom[dot]net
                                require 'sketchup.rb'
                                require 'TT_Lib2/core.rb'
                                TT;;Lib.compatible?('2.4.0', 'Inputbox Test')
                                module TT;;Plugins;;InputboxTest
                                  ### CONSTANTS ### --------------------------------------------------------
                                  VERSION = '1.0.0'
                                  ### MENU & TOOLBARS ### --------------------------------------------------
                                  unless file_loaded?( File.basename(__FILE__) )
                                    m = TT.menu('Plugins').add_submenu('TT;;GUI')
                                    m.add_item('TT;;GUI;;Inputbox')     { self.test_inputbox }
                                    m.add_item('TT;;Plugins;;CleanUp')  { self.test_cleanup }
                                  ### MAIN SCRIPT ### ------------------------------------------------------
                                  def self.test_inputbox
                                    options = {
                                      ;title => 'TT;;GUI;;Inputbox',
                                      ;pref_key => 'TT;;GUI;;Inputbox',
                                      ;modal => true,
                                      ;accept_label => 'Save',
                                      ;cancel_label => 'Abort'
                                    i = TT;;GUI;;Inputbox.new(options)
                                    i.add_control( {
                                      ;label => 'Hello',
                                      ;value => 'World',
                                      ;description => 'Lorem ipsum <b>dolor</b> sit amet.',
                                    i.add_control( {
                                      ;label => 'Checkbox1',
                                      ;value => true
                                    i.add_control( {
                                      ;label => 'Checkbox2',
                                      ;value => false
                                    i.add_control( {
                                      ;label => 'Integer',
                                      ;value => 123
                                    i.add_control( {
                                      ;label => 'Float',
                                      ;value => 1.23
                                    i.add_control( {
                                      ;label => 'Length',
                                      ;value => 1.23.m
                                    ms = Sketchup.active_model.materials
                                    i.add_control( {
                                      ;label => 'Dropdown List1',
                                      ;value => (ms.current) ? ms.current.display_name ; nil,
                                      ;options => ms.map { |m| m.display_name },
                                      ;description => 'Unordered ordered.'
                                    i.add_control( {
                                      ;label => 'Dropdown List2',
                                      ;order => 1,
                                      ;natrual_order => true,
                                      ;description => 'Naturally ordered.'
                                    i.add_control( {
                                      ;label => 'List1',
                                      ;order => -1,
                                      ;description => 'Naturally ordered reversed.',
                                      ;size => 5
                                    i.add_control( {
                                      ;label => 'List2',
                                      ;value => ms.to_a[0..1].map { |m| m.display_name },
                                      ;order => -1,
                                      ;description => 'Multiple Selection.',
                                      ;size => 5,
                                      ;multiple => true
                                    i.add_control( {
                                      ;label => 'Radioboxes1',
                                      ;value => 'Hello World',
                                      ;options => ['Hello World', 'Lorem Ipsum', 'Foo Bar'],
                                      ;type => TT;;GUI;;Inputbox;;CT_RADIOBOX
                                    i.add_control( {
                                      ;label => 'Radioboxes2',
                                      ;value => 'Monkeys',
                                      ;options => ['Cheese', 'Monkeys'],
                                    i.prompt { |results|
                                      puts 'Results returned;'
                                      p results
                                      #puts i.get_html
                                    def self.test_cleanup
                                    options = {
                                      ;title => 'TT;;Plugins;;CleanUp',
                                      ;pref_key => 'TT;;Plugins;;CleanUp',
                                      ;modal => true,
                                      ;accept_label => 'CleanUp',
                                      ;cancel_label => 'Cancel',
                                      ;align => 0.3
                                    i.add_control( {
                                      ;label => 'Scope',
                                      ;value => 'Local',
                                      ;options => ['Selected', 'Local', 'Model'],
                                      ;type => TT;;GUI;;Inputbox;;CT_RADIOBOX,
                                      ;group => 'General'
                                    i.add_control( {
                                      ;label => 'Validate Results',
                                      ;value => true,
                                      ;group => 'General'
                                    i.add_control( {
                                      ;label => 'Merge Coplanar Faces',
                                      ;value => true,
                                      ;group => 'Coplanar Faces'
                                    i.add_control( {
                                      ;label => 'Ignore Normals',
                                      ;value => false,
                                    i.add_control( {
                                      ;label => 'Ignore Materials',
                                      ;value => false,
                                    i.add_control( {
                                      ;label => 'Ignore UV',
                                      ;value => true,
                                    i.add_control( {
                                      ;label => 'Remove Duplicate Faces',
                                      ;value => false,
                                      ;group => 'Faces'
                                    i.add_control( {
                                      ;label => 'Repair Split Edges',
                                      ;value => true,
                                      ;group => 'Edges'
                                    i.add_control( {
                                      ;label => 'Remove Lonely Edges',
                                      ;value => true,
                                      ;group => 'Edges'
                                    i.add_control( {
                                      ;label => 'Remove Edge Materials',
                                      ;value => false,
                                      ;group => 'Edges'
                                    i.add_control( {
                                      ;label => 'Smooth Edges by Angle',
                                      ;value => 0.0,
                                      ;group => 'Edges'
                                      p results
                                      #puts i.get_html
                                  ### DEBUG ### ------------------------------------------------------------
                                  def self.reload
                                    TT;;Lib.reload
                                    load __FILE__
                                end # module
                                file_loaded( File.basename(__FILE__) )
                                Also thinking of adding more wrappers to create windows entirely from Ruby - buttons, lists, dropdowns etc...
                                input_test.rb
                                  Jim
                                  This approach will win. 👍
                                    When I made Vertex Tools I had a similar system for the toolbar system. A set of classes that acted as wrappers for the controls. The main classes where Container and Control - they would have most of the code. From there it was easier to create sub-classes like toolbars and buttons. I then had a very nice abstract layer where I created a toolbar class - where I added Button objects.
                                    Complex systems though - but I hope to have a base system by the new year.
                                      jeffschaid01
                                      Hello,
                                      I'm having a problem with the program crashing at 49% when exporting as a vrml. I've imported my bmp image, sized, indexed points and generated the mesh. Any suggestions?
                                      Thanks,
                                      Jeff
                                        @jeffschaid01 said:
                                        Hello,
                                        Thanks,
                                        Jeff
                                        Are you referring to Bitmap to Mesh?
                                        • GaieusG
                                          Yes, he is.
                                            Version 2.5.1
                                            • Fixes Webdialog issues with IE7
                                            • 15
                                            • 16
                                            • 1 / 16
