    Inferences Jump on Snow Leopard
    2 Posts 2 Posters 861 Views 2 Watching
    • J
      Jim57
      Maybe I don't mean inferences, but here's what happens.
      I upgraded to 10.6 and I'm using SU Pro, v 7.1.6859, on an early 2008 MacBook Pro.
      Since the upgrade, when I draw a line, I click one end, then line up to click the other. When I click, it sometimes jumps to a nearby location, perhaps 6 mm away. If I zoom closer, it does not jump. This also happens with Rotate.
      Also the ends of a line show as white squares about 3-4mm across, regardless of screen magnification. This means I have to zoom in really close to see where I'm clicking. It's a problem in close quarters and when dealing with intersections of curves, where very short segments get made by crossing lines. Sometimes the line ends show as the more usual colored dots.
      Best,
      Jim
      • O
        otb designworks
        I have found that the white squares occur sometimes after I have used the function keys to minimize, expose, etc. Without fail, a restart of Sketchup fixes this weirdness.
        I have found that inferences are less effective in SU7; sometimes it won't pick up intersecting points and sometimes it tries to pick up something behind the desired point. Definitely different than ver6, IMO.
        Cheers, Chuck
        OTB Designworks is on Youtube
