    Animate scaling with proper animation
    3 Posts 3 Posters 447 Views 3 Watching
    • N
      Niklaus
      hi,
      can anyone tell me if it's possible to animate the change of size of an object?
      nik
      • jeff hammondJ
        jeff hammond
        you can but it's not really an easy process (though i'm sure it could be automated via ruby)
        doing it manually as in this video, i scaled the ball up 1.05x then exported it (i used 2D jpgs).. i did that a few more times then compiled the exported images in quicktime..
        [flash=500,405:l28u5buk]http://www.youtube.com/v/5di_WP9SJLE?fs=1&hl=en_US&rel=0&color1=0x2b405b&color2=0x6b8ab6&border=1[/flash:l28u5buk]
        dotdotdot
          if you don't make a rotation and shadows, maybe you can make a move a long a perpendical path to the observer πŸ’­
          Result will be the same πŸ˜‰
          Else I don't believe you can animate the "size" between 2 scenes 😞
          Object will make first the move from scene 1 to scene 2 (movment of the same apparent new position resized) then make the "size" so that is hurting 😒
          I am curious of the Jeff operation πŸ˜„
