    πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
    My Xtratuf W.I.P
    10 Posts 5 Posters 1.1k Views 5 Watching
      Joshua
      http://img.photobucket.com/albums/v629/J-factory/WIP/Xtratuf1.jpg
      http://img.photobucket.com/albums/v629/J-factory/WIP/Xtratuf3.jpg
      Modeled from this boot:
      http://img.photobucket.com/albums/v629/J-factory/WIP/IMG_1531.jpg
      • jo-keJ Offline
        jo-ke
        I like following your workflow. I'm learning a lot of it.
        How did you connect and smooth the surface? with subdivide and smooth oder with the SU smoothing function?
        http://www.zz7.de
          Joshua
          Hi, no I didn't use any plug-ins. I had a component that was like a slice of a boot and i would copy that and scale it to match two profiles I had drawn of the boot. Since each slice had the same number of edges it was easy to connect the endpoints and then smooth it out.
          I imagine the plug-in is useful, but I haven't taken the time to try it.
          I had hidden geometry turned on when I was working but I always turned that off to take a picture and post it. πŸ˜„
          I finished the boots now, I'll post a picture.
          • F Offline
            FlapsyD
            Great ! especially without plug-ins πŸ˜‰ (don't know if I could without)
            Hope to see more of you in thye future.
            Flapsy
            • honoluludesktopH Offline
              honoluludesktop
              Joshua, This is a mesh, yes? Like:Temp77.jpg
              • P Offline
                Phil Rader AIA
                @joshua said:
                Yes, it looks like that mesh.
                Now I'm trying to put the label on.
                http://img.photobucket.com/albums/v629/J-factory/Label2.jpg
                1. make an outline of the logo image
                2. make the outline a group
                3. open the outline object and extrude it until it completely intersects the boot
                  4)close the logo shape group
                4. select the boot mesh and the logo shape group and intersect selected
                5. delete the logo shape group
                6. Explode the logo image and it becomes a texture
                7. select the exploded logo texture right click and select texture and make it a projected texture
                8. use the material selection eyedropper (hold down alt while you are in the paint bucket to sample the exploded and projected logo material
                9. with hidden lines turned off now you can paint that projected logo texture onto the patch of the boot that conforms to the shape of the logo
                10. now you can hide the lines that define the shape of the logo or soften them.
                voila you have the logo on the curved surface.
                there are other ways but this is just the old fashion way that I use.
                http://www.philrader.com
                  Joshua
                  http://img.photobucket.com/albums/v629/J-factory/WIP/Xtratuf6.jpg
                    Joshua
                    http://img.photobucket.com/albums/v629/J-factory/WIP/Xtratuf9.jpg
                      Joshua
                      http://img.photobucket.com/albums/v629/J-factory/WIP/Xtratufs.jpg
                        Joshua
                        http://img.photobucket.com/albums/v629/J-factory/WIP/Label2.jpg
