    Cylinder sides and dimensions
    2 Posts 2 Posters 615 Views 2 Watching
    • O Offline
      Octoleeber
      When using the create cylinder tool from the Sketchyphysics toolset is it possible to set the number of sides or sections?Is it also possible to type the dimensions you want as its created like when making a circle or can I change the dimensions after its made?
      Also when animating a cylinder with the proper animation plugin I still get rotation off of center when I create a circle then use the push pull tool,
      set position 1, rotate the cylinder then set position 2.
      When I move from pos 1 to pos 2 I get a rotation off of center.
      • O Offline
        Octoleeber
        Thanks for your reply,about the SP cylinder, I want to animate an SU cylinder with Proper Animation but It doent work for me most of the time. But by using the SP cylinder tool it will animate properly most every time.The advantage of making an SU cylinder is that I can set the number of sides and the dimensions as its made.There must be something different in the way an SP and SU cylinder is made or in the way I do it.
