    [Plugin] Sierpinski Tetrahedron
    3 Posts 3 Posters 5.4k Views 3 Watching
      Regular Polygon
      Hi all,
      I figured I'd write one more 3D fractal, and then I'll do something practical. This plugin will construct a Sierpinski Tetrahedron up to the seventh level. Access is from the Draw menu, which brings up a dialog box with 2 parameters for you to enter.
      The geometry is added to a component, which you can then place in the model. Here is an example of the fifth level tetrahedron.
      There is more documentation on the construction and usage, and a link to download the plugin, here: Sierpinski Tetrahedron.
      My SketchUp Plugins
        d12dozr
        Works great! Thanks, RP.
        http://goo.gl/f7ooYh
          Bravo to RegularPolygon! 😎
