π¨ Skimp | 25% Off until March 30 Buy Now
[Plugin] Sierpinski Tetrahedron
Hi all,
I figured I'd write one more 3D fractal, and then I'll do something practical. This plugin will construct a Sierpinski Tetrahedron up to the seventh level. Access is from the Draw menu, which brings up a dialog box with 2 parameters for you to enter.
The geometry is added to a component, which you can then place in the model. Here is an example of the fifth level tetrahedron.
There is more documentation on the construction and usage, and a link to download the plugin, here: Sierpinski Tetrahedron.
Works great! Thanks, RP.
