FLOORPLAN ON SKETCHUP
i am new with sketch up and i have recently used it to make a floor plan of a project since my autocad had crashed. i could i print the file i made in a large scale and not have low pixel lines or should i transfer it to another program such as revit or autocadd. is this possible?
Hi yna and welcome!
With the Pro version you can export your model (2d or 3d) into various vector based formats so yes, into revit or acad, too.
If you want to print it in high definition, at the bottom right of your print dialog you can set the quality or even check "Use high accuracy HLR" which will print it vector based.
There are a bunch of CAD programs that can even import SU files flawlessly, check out DoubleCAD for instance (it has a quite feature rich, free version with an option for a 30-day trial of the pro functions but you can opt out of it).
http://www.doublecad.com/
Register LoginAdvertisement
