    Quickest way to join 2 images? (using ImageMagick)
    5 Posts 3 Posters 578 Views 3 Watching
      Jim
      What's the quickest way to join 2 images into 1 either side-by-side or over-and-under?
      I typically have the following immediately available: GIMP, Paint.net, Irfranview, Picasa 3, FastStone Capture, FotoSketcher, ImageMagick, Windows Paint.
        does have the same size?
        Tut
        for
        Photofiltre
          MtnArch
          Serif's PanoramaPlus X4 works well for me (http://www.serif.com/AllProducts/Software/PhotoEditing/PanoramaPlusX4.htm) - which came with my PhotoPlus X4. Serif has a free version of PanoramaPlus X4 (http://www.serif.com/FreeDownloads/), just in case you'd like to try it before you actually buy it!
          I don't own stock in Serif's stuff, but I love their software - to me it's the best bang for the buck (SketchUp aside!). I've been a Serif user since the late '80's.
          Highest Regards,
          Alan T. Hendry, RA
          Architect
            Jim
            Thanks.
            I think I've worked out a pretty good solution using ImageMagick. ImageMagick is a very powerful image toolset, but runs from the command-line and has a incredible number of options.
            It turns out the tiling images problem has been solved multiple times, and I found a nice .bat file I could modify. Place the .bat file shortcut in your Send-To context menu, select some images and Send them to the batch file. That's it.
            The .bat looks like this, and can handle up to 9 selected images. ImageMagick does a good job guessing the best way to tile them.
              Jim
              More ImageMagick tricks:
              Convert a folder of .png's into an animated gif:
              Convert a folder of .png's into .jpg's:
              Convert a folder of .jpg's into a .mpg movie:
              $ convert *.jpg movie.mpg
              Create a single vertical image "stack" from a group of images:
              Create a single horizontal image from a group of images:
              Create a contact sheet from a group of images:
