    Problem with hinges / joint connector
    8 Posts 7 Posters 19.1k Views 7 Watching
      mburn16
      Hi everyone,
      I'm sure this question has been asked a dozen times before, so I'm sorry if I sound like a broken record...
      I just downloaded sketchy physics today, and I've been having problems. I'm trying to create a box with a free-fall door on the bottom, but my hinges aren't working. I pulled up a tutorial, and tried to follow it, without success. I create my box, make it a group, and turn it into a static object. Then I create the door, and group it with a hinge. The problem is that, when I try to connect the hinge to the box (making the box the parent object), it doesn't work. Either the door (+ hinge) falls away, OR the entire thing falls away.
      As far as I can tell, the joint connector isn't working properly.
      Any help is greatly appreciated.
      • Matt
        mburn16
        I've tried...unfortunately without luck.
        The problem seems to be in the joint connector itself - I cannot get both the joint and the parent object to highlight at the same time, even when holding down the ctrl key.
          mburn16
          only the left side huh?
          Yup, works like a charm...thx
            tslai88
            Hi, I got the same problem before. i am not sure whether is my notebook problem.
            i use left hand to hold the mouse, right hand to click & hold "Ctrl" button on the right side of the keyboard, the Joint Connector can't joint together. I click & hold left "Ctrl" button can joint.
            My right "Ctrl" workable for Copy / Rotate function.
            TSLai88
              artist1929
              Too am having this problem, I realize its an old thread but on my computer, I cannot get the joint connector to recognize both groups. I am using left cntrl but it will only allow me to select one of the two groups i'm trying to connect. Is there something i'm missing here? I've got a base and attched to it a "motor" thing. I'm trying to get connect it to a group that is placed directly above it on center with the motor button thing. When I select joint selector and use left control only 1 group will select. How do I get it to select the other group! ❓
                DanYHKim
                Could you describe your intended model? From what I have read, you want to make some kind of base with a motor on it. The motor is connected to another object that will rotate with the motor.
                You have constructed a 3D box and grouped its parts together, making the base. You then make a motor and connect it to the base box somehow (by grouping?). You then make a second 3D object and try to use the Joint Connector to connect this object to the motor.
                Is this correct?
                If so, one question is whether your base box needs to be able to move or be moved. If it is just sitting there, it really doesn't need to be grouped and attached to the motor; the motor can be placed arbitrarily in space, and then joint-connected to your rotating object. The motor will not move, since it is itself a static object.
                • E Offline
                  elek13
                  I have the same problem : neither left nor right control key works for joint connection. Both work in other Sketchup features.
                    T3485
                    Can you pass the fixer for wrong buttons in sketchyphysics?
