    Shape bender plugin
    3 Posts 3 Posters 679 Views 3 Watching
    • M
      mikendallas
      I could really use the shape bender plugin for what I want to do... its a great script but I cannot get it to work. I go to the drop down plugin and see chris fullmer tools, follow the process as described in tutorials, but when time to select the tool, there is no sin curve close to the white arrow tool, thus nothing happens to the selected group. Should I delete it and re-install it or am I just missing something here.
      Thanks, Michael
      • gullfoG
        gullfo
        check further into this forum. there are some other plugin updates you need to make in order to get it working. once you do get it working it's really amazing!
        Glenn
        http://www.runnel.com
        • Chris FullmerC
          Hi Mike, I guess you missed the help we offered earlier. It was sort of hidden in a thread on another topic. Check it out here:
          http://forums.sketchucation.com/viewtopic.php?f=323&t=30023&p=263719#p263719
          It would probably be best to respond here in this thread though, so we can keep things organized. So check out those answers and hints given there, see if anything helps. And then please respond in this thread if it worked, or if you still need more help. Thanks!
          Chris
          All my Plugins I've written
