    Exporting to 3D Model
    5 Posts 3 Posters 441 Views 3 Watching
    • G Offline
      GenX79
      I'm trying to export a Sketchup model as a 3d model. What I want to know is, is there any format that Google Sketchup can export to, where the Sketchup model's "paint-job", textures and edges are also transeferred over to new exported format?
      i.e. can a Sketchup model be exported "as is"?
      • honoluludesktopH Offline
        honoluludesktop
        Isn't the purpose of Collada to do that? If there is a problem with that, it may be the translation of the information by the importing software that changes the images.
        I am a dxf advocate, but only because I am only concerned with information that is required for production drawings. For me, SU, render, and other presentation apps are sufficient to accomplish all I require for modeling and presentation.
        • Z Offline
          Zacchia
          Do you work with SU pro? If not you can not export files. I would export as obj file. It should keep any material specifications.
          • G Offline
            GenX79
            Yes, we have SU pro here. I've tried exporting models in .3ds and .dae, then importing in to 3ds Max and they never retain their appearance. I haven't tried .obj format yet. And if worse comes to worse, I'll try to unwrap the model and re-texture it. Can you recommend a good unwrapping plug-in made for Sketchup?
            • Z Offline
              Zacchia
              Sorry no because for this i do not have enough knowhow 😞
