    SketchUP 7.1 Free + SketchUP 7.1 Pro
    10 Posts 4 Posters 904 Views 4 Watching
      stonebreaker
      hi,
      is it possible to use both versions of sketchup 7.1 simultaneously on my system??
        No, I am afraid unless you hack your system somehow. Practically both versions are the same (with the Pro having some extra) and use the same system registry.
        It was possible with version 5 but since v.6, it has not been possible.
          stonebreaker
          THX
          what a shame. -.-
          i was going to use the no plugin contaminated sketchup 7.1 free version for base modelling.^^
          • boofredlayB Offline
            boofredlay
            Why not have two plugin's folders. Then rename them before you start SU. No need for two installations. For example this is what I have...
              stonebreaker
              well...the idea is not bad.... i like it πŸ˜„
                stonebreaker
                please...can you upload a screenshot with the original plugin folder content?
                  boofredlay
                  Sure. Here is the Original Plugins folder and what is contained in each folder within...
                    stonebreaker
                    thx dude!! πŸ˜„
                      Ben Ritter
                      Doesn't that mess up all the menu locations then?
                        boofredlay
                        Sure. You will have to re-adjust your toolbars and what not but this is a solution to the original request.
