    Naming Components
    6 Posts 4 Posters 1.1k Views 4 Watching
    • John SayersJ Offline
      John Sayers
      Forgive me if this has been reported but when you create a component and save it with a specific name it ends up with a group#number.
      • utilerU Offline
        utiler
        Really, John? can you post an example?
        Just Curious...
          That should only happen when you turn a group into a component.
          Still an annoying feature as I need to go to find it, rename and set all the attributes afterwards instead of the component window popping up.
            John Sayers
            on further investigation I've found that the component is correctly named in the windows folder where it resides but it is named Group## in the components pulldown in sketchup, very annoying.
            BHTW another annoying problem is construction lines colour. I use bright pink as it usually stands out over other colours but it appear grey UNLESS I have switched on Axes. Then it turns to pink. In other words I can't have pink lines unless I turn on axes. Weird.
            Have you noticed that your current project could be named and saved as Client_1.skp yet in the task bar it appears as Untitled.skp
            These are all new bugs that have appeared in version 7. I'm reticent to try any further updates.
            • utilerU Offline
              utiler
              They are weird outcomes, John. I'll have to try the pink construction line and see.
              Just Curious...
              • bazB Offline
                baz
                quote:on further investigation I've found that the component is correctly named in the windows folder where it resides but it is named Group## in the components pulldown in sketchup, very annoying.
                Me too, but not consistently, ie: some take the name, some don't.
                I dont have the guide problem tho'
                Baz
                Windows7
