    Pirenesi
    3 Posts 2 Posters 318 Views 2 Watching
    • E Offline
      eccowboy
      Question, sometimes when I'm in the above, the pan mode is on, the hand, anyway when I click on another icon, the hand command won't change to
      the command that I just selected. It's like it's locked. Can someone tell
      why why this happens and why I can't change the command. I'll select
      the bulb to do a lighting and the pan command won't change.
      • Chris FullmerC Offline
        Hey Cowboy, is this a SketchUp quetion or Piranesi question? The terms you're using seem like that could be referring to SketchUp. But the title suggests Piranesi. If you are having Piranesi questions, you might have more luck on the Piranesi website. Do they have forums over there. Just a thought. But then again, people here are quite helpful, if someone knows the answer (not me), maybe they'll speak up, even if its not SU related.
        Chris
        All my Plugins I've written
        • E Offline
          eccowboy
          Chris, this is a pirenesi question, the hand icon sometimes stays active and I can't change the command,
