    Question
    2 Posts 2 Posters 287 Views 2 Watching
      David Will
      Hi Guys, I would like to thank you for this awesome website. I have some questions:
      1. Is there a way to develop a web application to interact with the model in sketchup? i.e. load,remove, make transparent etc...
      2. Say I have 2 groups defined in sketchup, Can I use the application mentioned above to store each group as a record in the database?
      3. Does sketchup have model interactivity i.e. if i select a group right click on it and select a defined menu item can I get a data grid that contains the info related to that group?
      Thank you for your patience and guidance
      • ToboboT Offline
        Tobobo
        Ok, firstly welcome,
        and yes I remember there being a discussion about this at somepoint. There are 3d Pdfs available now which be a solution.
        1. Say I have 2 groups defined in sketchup, Can I use the application mentioned above to store each group as a record in the database.
        2. Does sketchup have model interactivity i.e. if i select a group right click on it and select a defined menu item can I get a data grid that contains the info related to that group?[/
        There is a plugin called 'stock maker' where you can select a component and give it some values etc. Though I'm not sure you can export a data base from it but i think you can.
        Hope that helps
        Toby
        Philippians 4:13
