    Problems with script
    4 Posts 3 Posters 377 Views 3 Watching
    • P Offline
      Pout
      Can someone test this piece of code on the attached model?
      For me it does not erase the entities (all text)
      Any ideas?
      Sketchup.active_model.entities.each{|e| e.erase! if e.layer.name=='_4D_Finish_Text' || e.layer.name=='_4D_Start_Text' }
      Untitled.skp
      • Didier BurD Offline
        Didier Bur
        It works, but to make it work you have to run the piece of code several times, until everything is erased.
        entities method returns a collection of entities. When you have to erase more than one entity, better use 'erase_entities', like this:
        def xxx()
        arrayents=[]
        Sketchup.active_model.entities.each{|e| arrayents.push(e) if (e.layer.name=="_4D_Finish_Text" or e.layer.name=="_4D_Start_Text") }
        Sketchup.active_model.entities.erase_entities(arrayents)
        Everything's gone in one go πŸ˜‰ Hope this helps,
        DB
        • P Offline
          Pout
          Great! That works excellent.
          I wonder why it does not delete everything with the method i suggested.
          I think i will need to review some of my code. Is erase the only method that gives this 'problem'?
          Thx again Didier
            You should NOT change a collection of entities you are iterating through...
            NO-NO=
            YES-YES=
            Sketchup.active_model.entities.to_a.each{|e| e.erase! if e.layer.name=='_4D_Finish_Text' || e.layer.name=='_4D_Start_Text' }
            Note how the entities is made into frozen array [.to_a] before processing...
            To remove such items from inside all definitions use
            Sketchup.active_model.definitions.each{|d|d.entities.to_a.each{|e| e.erase! if e.layer.name=='_4D_Finish_Text' || e.layer.name=='_4D_Start_Text' })
            πŸ€“
            EDIT: typo corrected '.to_a' added to final example 😳
