    PC v MAC webdialog populate
    45 Posts 4 Posters 7.2k Views 4 Watching
      Thomthom - thanks for the example - so it appears that the embedded js solution works consistently but the ruby run-script with .setAttribute() etc doesn't - it's weird ?
      I have tested it on my PC and it needed a tweak to do what I actually wanted - here's a version that sets only the first nested checkbox checked when the main one is checked [they all become enabled] - the other two nested checkboxes remain unchecked until you click on them - on unchecking the main one all of the nested ones are unchecked and disabled as required...
      <html>
      <head>
        <title>Checkbox Test</title>
        <script type="text/javascript">
      window.onload = init;
      function $(id)
        return document.getElementById(id);
      function init()
        $('ch1').onclick = function()
          $('ch2').checked = this.checked;
          if (!this.checked)
            val = this.checked
          else
            val = !this.checked
          $('ch3').checked = val;
          $('ch4').checked = val;
          $('ch2').disabled = !this.checked;
          $('ch3').disabled = !this.checked;
          $('ch4').disabled = !this.checked;
        </script>
      </head>
      <body>
      <p>
      <label for="ch1">Checkbox 1</label>
      <input type="checkbox" id="ch1" />
      </p>
      <fieldset>
        <p>
        <label for="ch2">Checkbox 2</label>
        <input type="checkbox" id="ch2" disabled="disabled" />
        </p>
        <p>
        <label for="ch3">Checkbox 3</label>
        <input type="checkbox" id="ch3" disabled="disabled" />
        </p>
        <p>
        <label for="ch4">Checkbox 4</label>
        <input type="checkbox" id="ch4" disabled="disabled" />
        </p>
      </fieldset>
      </body>
      </html>
      All it needs now is some auto-value setting when a checkbox is changed so that these can be read out into Sketchup when needed... πŸ€“
        Your Ruby script calls a JS method that use setAttribute?
        Why not just .checked ? I didn't try setAttribute at all, as checked seemed to work on all platforms.
            // Make all checkbox's values reflect their checked state.
            var inputs = document.getElementsByTagName('input');
            for ( i=0; i < inputs.length; i++ )
              input = inputs[i];
              if ( input.getAttribute('type') == 'checkbox' )
                input.onchange = update_checkbox;
                input.onclick = update_checkbox; // for IE
                input.onkeyup = update_checkbox; // for IE
          function update_checkbox()
            this.value = this.checked.toString();
            this.title = this.checked.toString();
            hm.... that did not work under IE...
              Updated the post.
              That should work.
              NOTE! the onChange event triggers in IE when the input looses focus - so I attached the same event handler to onClick and onKeyUp to force immediate update. But if you use the this snippet with the other example the two onClick events will override each other and only one will trigger. You'd need to attach the event instead to make both event handlers work.
              • 3 / 3
