    How Steve Job found the time to be successful!
    11 Posts 3 Posters 669 Views 3 Watching
    • Mike LuceyM Offline
      Mike Lucey
      ..... he doesn't have to think about what to wear πŸ˜‰
      • daleD Offline
        dale
        Is that a codpiece? πŸ˜„
          Mike Lucey
          I'll text him and ask ....
            Mike Lucey
            He must have been working late. Just got this,
            *Hi Mike,
            I've often been asked about that. Its actually an inbuilt zipper antenna .... no reception problems with my 'personal' equipment πŸ‘
            Steve J*
            • daleD Offline
              dale
              Well you know with sensitve equipment like that it's all in the way its held πŸ˜‰
                Mike Lucey
                ..... I couldn't agree more with you Dale. Hold on I'll text him on hold he advised the zipper antenna should be held πŸ˜‰
                  Mike Lucey
                  ...... Wow, this was a quick response ..... he must be getting great reception with that zipper antenna. This is what Steve advises.
                  *'Hi Mike,
                  I'd suggest that the best way to achieve max reception is to unfurl the zipper antenna and start waving it about. The more its unfurled the better. If you can get help with this, even better reception can be achieved.
                  Let me know how you get on.
                  Steve J'*
                  • BoxB Offline
                    Does he use one of those tight fitting rubbery cases for his zip antenna, and if so does he find the textured ones provide greater sensitivity in his reception?
                      Mike Lucey
                      .... good question Box. I'll ask him about that ....
                        Mike Lucey
                        ..... this is what he says ....
                        *'Hi Mike,
                        This is tricky! Under normal reception I prefer to go 'natural' πŸ˜‰ but if I find myself outside of my normal reception area I would definitely use a protective rubber case in order not to damage the old zipper antenna.
                        Steve J'*
                        • daleD Offline
                          dale
                          That's twice I've spit my coffee out.... 🀣
