    Batch-jpg-export
    3 Posts 2 Posters 319 Views 2 Watching
    • artmusicstudioA Offline
      artmusicstudio
      hello everybody,
      i already tried some ruby-scripts for a batch-jpg-export of the scenes, but all of them does not respect the "view-based" text type.
      does anybody know a script, which:
      -only export the active scenes (scene manager including)
      -use the particular setting of each scene (shadow etc.)
      -shows correctly the "view-based" text
      -uses the name of the scene for the export - name of each jpg
      -eventually gives you an opportunity for fixing the jpg-settings, like width/length
      -eventually creates a new folder for he jpg's in the active project folder of the skp-file
      any other nice ideas?
      thanx a lot for helping
      regards stan
        Hi Stan,
        When I need to batch export scene based images, I generally export them as animation (as still images, not avi or such of course) with transition setting (say) 1 second and 1 frame/second frame rate.
        It won't do everything that you mention (like naming scenes) but is a pretty straightforward method
          artmusicstudio
          hi, thanx a lot,
          i used this method for a long time, until i found a great script (ruby) exporting only active scenes (scene setting > video on) and giving the jpg's it's scene-name ( very helpfull with 200 different views printed etc. for some sorting etc.)
          but right today i found this problem with the fixed text (which is helpfull for sinple logo-infos) not working in this script somehow.
          anyway, we keep on looking for a way..
          thank you
          regards stan
