    Piranesi V5
    extensions
    3 Posts 2 Posters 1.0k Views 2 Watching
    • E Offline
      eccowboy
      I'm new to this rendering program. My biggest problem is setting up a new drawing.
      Especially when I want to insert people, objects. Sometimes it works, other times, not.
      Can sometime give me easy instructions, I don't have a problem importing my sketchup
      drawing, but after that. I work in feet and inches.
      Thanks,
        sorgesu
        That is a really open ended question. More specific information would be required to be of any real help.
        If you have the insertion of entourage working only some of the time, my first guess would be that you accidently leave one of the "locks" on when you are placing entourage, sometimes. Make sure all locks: colour, material, orientation, plane are all OFF when placing entourage or it won't work.
        Aside from that obvious one, I would need more specifics for each given problem. Hope that helps a bit.
        Susan Sorger
        • E Offline
          eccowboy
          thanks for your help, my other question is when I initially set up a drawing what is the correct procedure for setting up drawing units. I typically work in feet and inches, not meters.
          Michael Fellman
