    Maisons individuelles
    38 Posts 8 Posters 7.9k Views 8 Watching
    • DVERGERD Offline
      DVERGER
      Quelques maisons sur lesquelles je travaille en ce moment (rendu VRay).
      J'ai déja fait quelques retouches de niveaux/contraste/saturation et surtout l'horizon trop haut de la mer.
      Some houses on which I work at this time (made VRay).
      I have already made some minor levels / contrast / saturation and too high above the horizon of the sea.
      http://www.3dvf.com/forum/mesimages/38375/Maison1.jpg
      http://www.3dvf.com/forum/mesimages/38375/Maison2.jpg
      http://www.3dvf.com/forum/mesimages/38375/Maison3.jpg
      http://www.3dvf.com/forum/mesimages/38375/Maison4.jpg
      http://www.3dvf.com/forum/mesimages/38375/Maison5.jpg
        ça pousse bien les palmiers en Picardie? 😄
        (enfin je dis Picardie par rapport à la végétation des arbres et taillis de la première photo 😄
        Pas par rapport à rapport à l'architecture 😄
          Roger
          In the last render the shadow and the sun highlights seem to be working in opposite directions.
          http://www.azcreative.com
          • DVERGERD Offline
            DVERGER
            En Picardie je sais pas mais en Bretagne près de la côte, oui. 😉
            • DVERGERD Offline
              DVERGER
              Thank you, I made an update.
              • honoluludesktopH Offline
                honoluludesktop
                Nice texture for grass, and your hedges are much better then mine. There has got to be a easy way to make the ground plane (the lawn) more realistic. Maybe with small bumps and slopes. I struggle the most with cultivated hedges and lawns.
                • DVERGERD Offline
                  DVERGER
                  I'm pretty happy with the lawns. I made some edits since.
                  Where I have the greatest difficulty is with the windows. For something more realistically. I must find a way to get the transparancy and at the same time some reflections.
                    honoluludesktop
                    Btw, that's a interesting detail you have, a vertical looking mansard (don't know what else to call it) returning along side the wall. And, no overhangs. Very nice, in my part of the world, overhands are a necessity, so no clean simple volume.
                      Roger
                      The house with the ocean in the background does not have a correct perspective. The projections of the perspective lines should meet on the horizon. The way it looks now is that the house is tilting backwards and sliding into the bay. Move your horizon line down to be in the middle of the little window or raise your camera 10'.
                      • DVERGERD Offline
                        DVERGER
                        Une autre, en tuiles cette fois.
                        Another, tiles this time.
                        http://pics.imagup.com/member4/1282809939_Maison7.jpg
                          Le crépi tire un peu sur le vert, non?
                          • DVERGERD Offline
                            DVERGER
                            Le crépis non (vérifié avec la pipette 11x11 = RVB: 219, 210, 181). Par contre sous le porche c'est un bardage, lui de couleur gris-vert.
                              Alors c'est mon écran ou mes yeux car j'ai façade éclairée côté gauche de la fenêtre 😄
                              214 213 178 pas si éloignés
                              • DVERGERD Offline
                                DVERGER
                                Pratiquement fini mon travail.
                                http://pics.imagup.com/member4/1283353680_Maison8.jpg
                                • teufT Offline
                                  teuf
                                  Ma fois...J'aime beaucoup ! 😄
                                  Les textures et biblios sont incorporés au logiciel ?
                                  Je n'accroche pas trop l'hyperéalisme, mais là c'est ni trop ni trop peu, ni froid, ni plastoc, ça n'agresse pas l'oeil, c'est agreable, accuillant 😛
                                  Bref ça me donne envie d'aller plus loin que sketchup + photoshop.
                                  Teuf
                                  • artysmediaA Offline
                                    artysmedia
                                    I like the composition of the firsts! 😄 👍
                                    Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
                                    Blog: Artysmedia
                                      binouze23
                                      Salut DVERGER,
                                      j'avais le même problème que toi au niveau des vitrages, essaye d'ajouter une source lumineuse à l'intérieur et tes vitrage devraient mieux montrer leur transparence...
                                      désavantage de cette technique :
                                      1. temps de rendus plus long
                                      2. mieux vaut modéliser un brin l'intérieur si les vitres sont transparentes 😉
                                      voici un exemple :
                                      dans cette vue, la nouvelle annexe est éclairée de l'intérieur = vitrage transparent et réfléchissant
                                      la partie ancienne (sur la droite et derrière) elle n'est pas éclairée par l'intérieur = vitrage mirroir
                                      pourtant le matériaux vray est le même...
                                      Exemple vitrage
                                      Maintenant c'est ma solution mais étant donné que je ne m'y connait pas encore très bien dans les réglages de matériaux ca n'est surement pas la meilleure manière de faire... mais quelqu'un comme Thomtom pourra surement te donner une meilleure technique 😉
                                      sinon très jolies tes images, très douces, ... c'est vrai qu'il y a des différences entre le fond et l'éclairage de la scène mais vu que je suis très mauvais dans ce domaine... je ne me permettrais pas de te huer... 🤣
                                        Ou l'art de rassembler les voisins! 😆
                                        La piscine! 😄
                                          binouze23
                                          La piscine! 😄
                                          et non... c'est la même propriété 😄
                                          l'annexe relie l'habitation actuelle à une grange transformée en salle de jeu...
                                          c'est trop grand à mon gout mais bon il ont les moyens et c'est ce qu'ils veulent donc... 👍
                                          sorry pour le hors sujet madame mais c'est Pilou qui à commencé en premier Na ! 🤣
                                            Alors pourquoi ne pas avoir garder les charmantes tuiles rouges que l'on aperçoit dans le 3ème bâtiment? 😄
                                            C'est bizarre ce mélange de nature de toitures 😉
                                            Et pourquoi c'est ouvert au-dessus du gars?
                                            Il va se faire rincer dès qu'il va pleuvoir 😆
                                            à moins de raser les murs à ce qu'on peut voir 💚
                                            • 1 / 2
