    Maisons individuelles
    38 Posts 8 Posters 8.9k Views 8 Watching
    • honoluludesktopH Offline
      honoluludesktop
      Nice texture for grass, and your hedges are much better then mine. There has got to be a easy way to make the ground plane (the lawn) more realistic. Maybe with small bumps and slopes. I struggle the most with cultivated hedges and lawns.
      • DVERGERD Offline
        DVERGER
        I'm pretty happy with the lawns. I made some edits since.
        Where I have the greatest difficulty is with the windows. For something more realistically. I must find a way to get the transparancy and at the same time some reflections.
          honoluludesktop
          Btw, that's a interesting detail you have, a vertical looking mansard (don't know what else to call it) returning along side the wall. And, no overhangs. Very nice, in my part of the world, overhands are a necessity, so no clean simple volume.
            Roger
            The house with the ocean in the background does not have a correct perspective. The projections of the perspective lines should meet on the horizon. The way it looks now is that the house is tilting backwards and sliding into the bay. Move your horizon line down to be in the middle of the little window or raise your camera 10'.
            http://www.azcreative.com
            • DVERGERD Offline
              DVERGER
              Une autre, en tuiles cette fois.
              Another, tiles this time.
              http://pics.imagup.com/member4/1282809939_Maison7.jpg
                Le crépi tire un peu sur le vert, non?
                • DVERGERD Offline
                  DVERGER
                  Le crépis non (vérifié avec la pipette 11x11 = RVB: 219, 210, 181). Par contre sous le porche c'est un bardage, lui de couleur gris-vert.
                    Alors c'est mon écran ou mes yeux car j'ai façade éclairée côté gauche de la fenêtre 😄
                    214 213 178 pas si éloignés
                    • DVERGERD Offline
                      DVERGER
                      Pratiquement fini mon travail.
                      http://pics.imagup.com/member4/1283353680_Maison8.jpg
                      • teufT Offline
                        teuf
                        Ma fois...J'aime beaucoup ! 😄
                        Les textures et biblios sont incorporés au logiciel ?
                        Je n'accroche pas trop l'hyperéalisme, mais là c'est ni trop ni trop peu, ni froid, ni plastoc, ça n'agresse pas l'oeil, c'est agreable, accuillant 😛
                        Bref ça me donne envie d'aller plus loin que sketchup + photoshop.
                        Teuf
                        • artysmediaA Offline
                          artysmedia
                          I like the composition of the firsts! 😄 👍
                          Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
                          Blog: Artysmedia
                            binouze23
                            Salut DVERGER,
                            j'avais le même problème que toi au niveau des vitrages, essaye d'ajouter une source lumineuse à l'intérieur et tes vitrage devraient mieux montrer leur transparence...
                            désavantage de cette technique :
                            1. temps de rendus plus long
                            2. mieux vaut modéliser un brin l'intérieur si les vitres sont transparentes 😉
                            voici un exemple :
                            dans cette vue, la nouvelle annexe est éclairée de l'intérieur = vitrage transparent et réfléchissant
                            la partie ancienne (sur la droite et derrière) elle n'est pas éclairée par l'intérieur = vitrage mirroir
                            pourtant le matériaux vray est le même...
                            Exemple vitrage
                            Maintenant c'est ma solution mais étant donné que je ne m'y connait pas encore très bien dans les réglages de matériaux ca n'est surement pas la meilleure manière de faire... mais quelqu'un comme Thomtom pourra surement te donner une meilleure technique 😉
                            sinon très jolies tes images, très douces, ... c'est vrai qu'il y a des différences entre le fond et l'éclairage de la scène mais vu que je suis très mauvais dans ce domaine... je ne me permettrais pas de te huer... 🤣
                              Ou l'art de rassembler les voisins! 😆
                              La piscine! 😄
                                binouze23
                                La piscine! 😄
                                et non... c'est la même propriété 😄
                                l'annexe relie l'habitation actuelle à une grange transformée en salle de jeu...
                                c'est trop grand à mon gout mais bon il ont les moyens et c'est ce qu'ils veulent donc... 👍
                                sorry pour le hors sujet madame mais c'est Pilou qui à commencé en premier Na ! 🤣
                                  Alors pourquoi ne pas avoir garder les charmantes tuiles rouges que l'on aperçoit dans le 3ème bâtiment? 😄
                                  C'est bizarre ce mélange de nature de toitures 😉
                                  Et pourquoi c'est ouvert au-dessus du gars?
                                  Il va se faire rincer dès qu'il va pleuvoir 😆
                                  à moins de raser les murs à ce qu'on peut voir 💚
                                  • DVERGERD Offline
                                    DVERGER
                                    Teuf
                                    Merci pour le "ni trop ni trop peu" et surtout le "pas plastoc"
                                    Non il faut tout créer pour faire fonctionner le logiciel. Ma matière n'est pas vraiment compliqué puisque c'est un simple bump sur une couleur (pour l'enduit).
                                    Ensuite les vitres sont retouchées sur Toshop.
                                    Arbres, pelouse et autres sortent d'une bibliothèque achetée sur le net.
                                    • DVERGERD Offline
                                      DVERGER
                                      Merci toi aussi pour le "tres douces". C'est aussi le commentaire que j'ai eu ici au boulot.
                                      Ca fait plaisir de parler en français avec quelqu'un qui utilise VRay4SU.
                                      Je reviendrai vers toi prochainement, là c'est un long week end (avec le pont). Ciao!
                                      • DVERGERD Offline
                                        DVERGER
                                        d'autres maisons, tuiles et faible pente.
                                        http://uppix.3dvf.com/images/maison8.jpg
                                        http://uppix.3dvf.com/images/maison7.jpg
                                        • DVERGERD Offline
                                          DVERGER
                                          Yet another, this time with flat tiles
                                          • DVERGERD Offline
                                            DVERGER
                                            Ma première image pour une maison en ossature bois.
                                            Toiture végétalisée et bâtiment basse consommation.
                                            My first image for a timber frame house.
                                            Green roof construction and low power consumption.
