    Maisons individuelles
    38 Posts 8 Posters 9.7k Views 8 Watching
    • DVERGERD Offline
      DVERGER
      @roger said:
      In the last render the shadow and the sun highlights seem to be working in opposite directions.
      Thank you, I made an update.
      • honoluludesktopH Offline
        honoluludesktop
        Nice texture for grass, and your hedges are much better then mine. There has got to be a easy way to make the ground plane (the lawn) more realistic. Maybe with small bumps and slopes. I struggle the most with cultivated hedges and lawns.
        • DVERGERD Offline
          DVERGER
          I'm pretty happy with the lawns. I made some edits since.
          Where I have the greatest difficulty is with the windows. For something more realistically. I must find a way to get the transparancy and at the same time some reflections.
            honoluludesktop
            Btw, that's a interesting detail you have, a vertical looking mansard (don't know what else to call it) returning along side the wall. And, no overhangs. Very nice, in my part of the world, overhands are a necessity, so no clean simple volume.
              Roger
              The house with the ocean in the background does not have a correct perspective. The projections of the perspective lines should meet on the horizon. The way it looks now is that the house is tilting backwards and sliding into the bay. Move your horizon line down to be in the middle of the little window or raise your camera 10'.
              http://www.azcreative.com
              • DVERGERD Offline
                DVERGER
                Une autre, en tuiles cette fois.
                Another, tiles this time.
                http://pics.imagup.com/member4/1282809939_Maison7.jpg
                  Le crépi tire un peu sur le vert, non?
                  • DVERGERD Offline
                    DVERGER
                    Le crépis non (vérifié avec la pipette 11x11 = RVB: 219, 210, 181). Par contre sous le porche c'est un bardage, lui de couleur gris-vert.
                      Alors c'est mon écran ou mes yeux car j'ai façade éclairée côté gauche de la fenêtre 😄
                      214 213 178 pas si éloignés
                      • DVERGERD Offline
                        DVERGER
                        Pratiquement fini mon travail.
                        http://pics.imagup.com/member4/1283353680_Maison8.jpg
                        • teufT Offline
                          teuf
                          Ma fois...J'aime beaucoup ! 😄
                          Les textures et biblios sont incorporés au logiciel ?
                          Je n'accroche pas trop l'hyperéalisme, mais là c'est ni trop ni trop peu, ni froid, ni plastoc, ça n'agresse pas l'oeil, c'est agreable, accuillant 😛
                          Bref ça me donne envie d'aller plus loin que sketchup + photoshop.
                          Teuf
                          • artysmediaA Offline
                            artysmedia
                            I like the composition of the firsts! 😄 👍
                            Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
                            Blog: Artysmedia
                              binouze23
                              Salut DVERGER,
                              j'avais le même problème que toi au niveau des vitrages, essaye d'ajouter une source lumineuse à l'intérieur et tes vitrage devraient mieux montrer leur transparence...
                              désavantage de cette technique :
                              1. temps de rendus plus long
                              2. mieux vaut modéliser un brin l'intérieur si les vitres sont transparentes 😉
                              voici un exemple :
                              dans cette vue, la nouvelle annexe est éclairée de l'intérieur = vitrage transparent et réfléchissant
                              la partie ancienne (sur la droite et derrière) elle n'est pas éclairée par l'intérieur = vitrage mirroir
                              pourtant le matériaux vray est le même...
                              Exemple vitrage
                              Maintenant c'est ma solution mais étant donné que je ne m'y connait pas encore très bien dans les réglages de matériaux ca n'est surement pas la meilleure manière de faire... mais quelqu'un comme Thomtom pourra surement te donner une meilleure technique 😉
                              sinon très jolies tes images, très douces, ... c'est vrai qu'il y a des différences entre le fond et l'éclairage de la scène mais vu que je suis très mauvais dans ce domaine... je ne me permettrais pas de te huer... 🤣
                                Ou l'art de rassembler les voisins! 😆
                                La piscine! 😄
                                  binouze23
                                  La piscine! 😄
                                  et non... c'est la même propriété 😄
                                  l'annexe relie l'habitation actuelle à une grange transformée en salle de jeu...
                                  c'est trop grand à mon gout mais bon il ont les moyens et c'est ce qu'ils veulent donc... 👍
                                  sorry pour le hors sujet madame mais c'est Pilou qui à commencé en premier Na ! 🤣
                                    Alors pourquoi ne pas avoir garder les charmantes tuiles rouges que l'on aperçoit dans le 3ème bâtiment? 😄
                                    C'est bizarre ce mélange de nature de toitures 😉
                                    Et pourquoi c'est ouvert au-dessus du gars?
                                    Il va se faire rincer dès qu'il va pleuvoir 😆
                                    à moins de raser les murs à ce qu'on peut voir 💚
                                    • DVERGERD Offline
                                      DVERGER
                                      Teuf
                                      Merci pour le "ni trop ni trop peu" et surtout le "pas plastoc"
                                      Non il faut tout créer pour faire fonctionner le logiciel. Ma matière n'est pas vraiment compliqué puisque c'est un simple bump sur une couleur (pour l'enduit).
                                      Ensuite les vitres sont retouchées sur Toshop.
                                      Arbres, pelouse et autres sortent d'une bibliothèque achetée sur le net.
                                      • DVERGERD Offline
                                        DVERGER
                                        Merci toi aussi pour le "tres douces". C'est aussi le commentaire que j'ai eu ici au boulot.
                                        Ca fait plaisir de parler en français avec quelqu'un qui utilise VRay4SU.
                                        Je reviendrai vers toi prochainement, là c'est un long week end (avec le pont). Ciao!
                                        • DVERGERD Offline
                                          DVERGER
                                          d'autres maisons, tuiles et faible pente.
                                          http://uppix.3dvf.com/images/maison8.jpg
                                          http://uppix.3dvf.com/images/maison7.jpg
                                          • DVERGERD Offline
                                            DVERGER
                                            Yet another, this time with flat tiles
