    A line doesn't match with the model that I inserted
    layout
    3 Posts 2 Posters 1.5k Views 2 Watching
      Aftop
      Hello,
      I tried to put a line on a model that I want to present, but it seems that the grid is not sensitive enough that the line doesn't match the model. I tried with the GRID box, but can't manage it. Anybody have any idea?
      Thank you in advance.
      Sunny
      example
        danbig
        Hi Sunny -
        It looks like you are trying to get the highlighted line in LayOut to align perfectly with the line on your sketchup model viewport. Is this correct?
        It also sounds like you are using "snap to grid" as a method for aligning the objects. I would suggest turning off "snap to grid" and turning on "snap to objects". I think this will allow you to draw or move your line so it is exactly aligned with the points you want on your sketchup model.
          Aftop
          Thanks for your reply.
          I must have been confused between "Grid" and "Object Snap".
          Now I can align my line with my model. (overlap)
          Thanks again for your answer. It was ice water to my thirst!
          Sunny
