    Auto add numbers in Ruby?
    12 Posts 5 Posters 779 Views 5 Watching
    • Chris FullmerC Offline
      I've forgotten how to do this the quick way (seem like there is a method already set up nicely for what I want).
      I want to take a string and add numbers to the beginning of it.
      Chris
      Dan
      Jim
      Martin
      Thom
      becomes
      0001Chris
      0002Dan
      0003Jim
      0004Martin
      0005Thom
      Seems like there is a method I can use that does this automatically and smoothly for me, where I should be able to specify the amount of placeholders to use (in the example I show 4 10's places being held). Anyone recall what I'm thinking of? Just hte method is enough, I can look up its syntax again if you could kindly point me in the right direction. Thanks,
      Chris
      All my Plugins I've written
        Jim
        The easiest is to use strings and .next.
        "0000".next => "0001"
        Otherwise, if you use numbers you need to use printf or sprintf (aka format).
        10.times { |i|
          printf "%04d\n", i
        names = %w( Joe Mike Tim )
        names.each_with_index do |name, i|
          printf "%04d%s\n" % [i, name]
        See sprintf for details on formatting.
          Awesome, thanks Jim. It was string.next that I was trying to think of. That is all I needed, thanks again!
          Chris
          a = "000" 10.times do puts a a = a.next end
            Another way is: '1'.rjust(4, '0')
              You don't have to do this: a = a.next - you can instead do a.next!. Most probably that will be faster - thought not noticeable until you run many iterations.
              If you did not require '0000' then you could also do:
              a = '0000' 10.times{ puts a.next! }
                Ahh, good idea on the next! method. It didn't cross my mind that it might exist. I also like that rjust method. I'll look into that one too. Thanks Thom,
                Chris
                  todd burch
                  ...4 10's places....
                  HAR HAR HAR HAR HAR!!!!!!!
                    Laughing at my inability to express myself in functional english there Todd πŸ˜„, or is there a big inside joke I missed (both equally likely).
                    Chris
                    • Dan RathbunD Offline
                      Dan Rathbun
                      > end
                      index starts at 0, you'd need i+1 to start at 1
                      also.. printf "%04d%s\n" % [i, name]
                      is adding an extra operation eval that's not needed.
                      could be either:
                      puts "%04d%s\n" % [i+1, name]
                      or
                      printf("%04d%s\n",i+1,name)
                      I'm not here much anymore.
                        Dan Rathbun
                        Of course if your wanting to build up an Array of Hash keys (or Attribute Dictionary keys,) just create an empty array first
                        keys=[]
                        then replace the puts or printf with
                        keys.push
                          todd burch
                          Chris
                          The first.
                            Jim
                            Note to self: % is a method of Strings. Thanks.
