    Auto add numbers in Ruby?
    12 Posts 5 Posters 986 Views 5 Watching
    • Chris FullmerC
      I've forgotten how to do this the quick way (seem like there is a method already set up nicely for what I want).
      I want to take a string and add numbers to the beginning of it.
      Dan
      Jim
      Martin
      Thom
      becomes
      0001Chris
      0002Dan
      0003Jim
      0004Martin
      0005Thom
      Seems like there is a method I can use that does this automatically and smoothly for me, where I should be able to specify the amount of placeholders to use (in the example I show 4 10's places being held). Anyone recall what I'm thinking of? Just hte method is enough, I can look up its syntax again if you could kindly point me in the right direction. Thanks,
        Jim
        The easiest is to use strings and .next.
        "0000".next => "0001"
        Otherwise, if you use numbers you need to use printf or sprintf (aka format).
        10.times { |i|
          printf "%04d\n", i
        names = %w( Joe Mike Tim )
        names.each_with_index do |name, i|
          printf "%04d%s\n" % [i, name]
        See sprintf for details on formatting.
        • Chris FullmerC
          Awesome, thanks Jim. It was string.next that I was trying to think of. That is all I needed, thanks again!
          a = "000" 10.times do puts a a = a.next end
            Another way is: '1'.rjust(4, '0')
              You don't have to do this: a = a.next - you can instead do a.next!. Most probably that will be faster - thought not noticeable until you run many iterations.
              If you did not require '0000' then you could also do:
              a = '0000' 10.times{ puts a.next! }
              • Chris FullmerC
                Ahh, good idea on the next! method. It didn't cross my mind that it might exist. I also like that rjust method. I'll look into that one too. Thanks Thom,
                • T
                  todd burch
                  ...4 10's places....
                  HAR HAR HAR HAR HAR!!!!!!!
                  • Chris FullmerC
                    Laughing at my inability to express myself in functional english there Todd πŸ˜„, or is there a big inside joke I missed (both equally likely).
                    • Dan RathbunD
                      Dan Rathbun
                      > end
                      index starts at 0, you'd need i+1 to start at 1
                      also.. printf "%04d%s\n" % [i, name]
                      is adding an extra operation eval that's not needed.
                      could be either:
                      puts "%04d%s\n" % [i+1, name]
                      or
                      printf("%04d%s\n",i+1,name)
                      I'm not here much anymore.
                      • Dan RathbunD
                        Dan Rathbun
                        Of course if your wanting to build up an Array of Hash keys (or Attribute Dictionary keys,) just create an empty array first
                        keys=[]
                        then replace the puts or printf with
                        keys.push
                        • T
                          todd burch
                          The first.
                            Jim
                            Note to self: % is a method of Strings. Thanks.
