    Help me to up this :-(
    4 Posts 2 Posters 513 Views 2 Watching
    • M
      maximas
      please help me to up this forms about (8,5 METER°) i cant up them all , every time i get on tall than other and the system is imperial 😞
      thanks for help
      the file on TOP view , i would like all those form tall of 8,5 meter
      • GaieusG
        You can always set your units to metric under Window > Model info > Units (select decimal and then the unit).
        Even in a model with imperial units, you can enter metric units if you also type the unit - like 8,5m.
        But here is the file; did you want to extrude all the plans to 8,5m? (I now set the units to centimetres so they are all 850cm high).
        HELP.skp
        • M
          maximas
          Thankkkkk Youur for your helpp , but can you tell me how you do to extrude them all ?!
          when i teap an measure never it like etrude 😞
          • GaieusG
            You just need to extrude one to the correct height (with the PushPull tool ) then keep double clicking (still with the PushPull tool) on each face and they will repeat the same height.
