    Debug Traces in Sandbox From Contours
    7 Posts 3 Posters 673 Views 3 Watching
    • fredo6F Offline
      fredo6
      Inadvertedly, I discovered that in SU 7.1, the From Contourfunction of the Sandbox displays some traces in the Ruby console.
      Here is a small video showing it (I also enclosed the result of the operation with Curviloft. Note that TIG's ExtrudeByRail would produce the same result as Curviloft).
      Here is the trace of "from Contour"
      activated
      Getting Sel Edges
      In get sel edges
      @ss.length=53
      @totalEdges=53
      @avgLength = 11.0872419649578
      Starting work
      In EdgesToPtArray
      @ptSet.length=87
      In CreateTerrain
      pushing 1 on the end
      removing non-functional
      triangulating
      adding points
      adding polygons
      done
      Is anyone aware of that, or is it just me?
      Fredo
        Yea - sandbox tools are quite verbal.
        And there are others: Right clicking on model axis, or outside any geometry while inside a group/component:
        Error: #<LocalJumpError: return from proc-closure> C:/Program Files (x86)/Google/Google SketchUp 7/Tools/WebTextures/webtextures_loader.rb:894:incall'`
        And if you start SketchUp with the argument that routes the Ruby Console to file: "C:\Program Files (x86)\Google\Google SketchUp 7\Sketchup.exe" > myRubyLog.txt
        There is a great number of "free_Command" lines - this appear with no plugins installed.
        Incidentally, there's quite a few startup warnings from your plugins Fredo.
        myRubyLog.txt
        • fredo6F Offline
          fredo6
          Tom,
          Thanks. The ones for BZ may have disappeared in the new release of BezierSpline (you're still in version 1.2).
          The others with LibTraductor are inevitable, because, for compatibility reasons, I load twice LibTraductor code (the old file LibTraductor.rb for JoinPushPull and then the one from LibFredo6).
          Fredo
            Ah - indeed I am. Thought I'd them all updated. πŸ‘
              Still get messages:
              undefined method bz_ask_extras for BZ__BezierClassic in file bezierspline_main.rb
              undefined method bz_ask_extras for BZ__Polyline in file bezierspline_main.rb
              undefined method bz_ask_extras for BZ__Catmull in file BZ_Dir_13/BZ__Catmull.rb
              undefined method bz_ask_extras for BZ__Courbette in file BZ_Dir_13/BZ__Courbette.rb
              undefined method bz_ask_extras for BZ__CubicBezier in file BZ_Dir_13/BZ__CubicBezier.rb
              undefined method bz_ask_extras for BZ__FSpline in file BZ_Dir_13/BZ__FSpline.rb
                Looks as though Sandbox tools also outputs stuff during startup:
                ` key = Units
                value = 2.0
                key = StampOffset
                value = 39.3700787401575
                key = GridSpacingX
                value = 19.6850393700787
                key = SmooveRadius
                value = 157.48031496063
                key = GridSpacingY
                value = 19.6850393700787`
                • Dan RathbunD Offline
                  Dan Rathbun
                  The others [warnings] with LibTraductor are inevitable, because, for compatibility reasons, I load twice LibTraductor code (the old file LibTraductor.rb for JoinPushPull and then the one from LibFredo6).
                  When you next update the LibFredo6.. you can suppress the warnings when you know that your about to redefine old methods.
                  Save $VERBOSE to a reference, then set $VERBOSE to nil (silent mode,) when done overriding methods, reset $VERBOSE back to what it was. MAKE SURE YOU SET IT BACK !! (or some peeps may get angry.)
                  I'm not here much anymore.
