    Understanding repeating code In Ruby?
    5 Posts 4 Posters 552 Views 4 Watching
    • T
      tomot
      This topic has been troubling me since I left BASIC. Even as a novice I could understand Gosub and Goto. It simply meant I didn't have to repeat code, and I could jump to other subroutine.
      The attached pic shows 4 subroutines each can be selected from a drop down menu within a single Ruby script, I'm currently developing. Each of the 4 subroutine is contained within its own "If" statement.
      The option: populate area ABCD, subroutine contains only the possible ABCD, related XY points
      The option: populate area AD, subroutine contains only the possible AD, related XY points
      The option: populate area BC, subroutine contains only the possible BC, related XY points
      The option: populate area A, subroutine contains only the possible A, related XY points
      The script runs perfectly! Were it not for the fact that I know something about repeating code, I would never have asked the following question.
      Since all the code required for all possible XY points is already defined once in the ABCD "if" subroutine. How do I avoid repeating all of these xy points all over again in the "if" subroutines for other 3 options, (AD, BC, and A)?tile4.png
      my plugins
      tomot
      • TIGT
        Write a def inside the main code
        So
         def process_x(args=nil)
          ### args can say do it a certain way or data for the points etc
          ### do_your_stuff
         end#def
        then later in the main code do
        self.process_x(args)
        and it'll run the process_x with the 'args' for you...
        If you need to run it several times do something like
        [args1, args2, arggs3].each{|args|
        or
        3.times{|i|self.process_x(args)}
        • Dan RathbunD
          Dan Rathbun
          You write a method that has arguments (parameters) and inside the method you have conditional statements that do things according to that values of the arguments.
          module Tomot
            module Tile_wizard
              POINTS=[..array of points..]
              def populate( how='ABCD' )
                case how.to_s
                when 'ABCD'
                  # use your module POINTS array constant
                when 'AD'
                when 'BC'
                else # just do 'A'
                # you can put common code here
              end # method
              # you can def other methods here that
              # might be called by the populate method
              begin # run once when module loads
                # setup your toolbar & menu
                # to call Tomot;;Tile_Wizard.populate(arg)
                # where arg can be the String or Symbol,
                # ie ;ABCD or 'ABCD'
            end # module
          end # module
          I'm not here much anymore.
          • T
            tomot
            thank you for your input!
            my plugins
            tomot
            • J
              Jim
              With this, you can use any combination of ABCD.
              blocks = UI.inputbox(["Blocks [ABCD]?"])[0]
              populateA() if blocks[/A/]
              populateB() if blocks[/B/]
              populateC() if blocks[/C/]
              populateD() if blocks[/D/]
              Or even..
              letters = blocks.split(//)
              letters.each do |letter|
                populate(letter, etc)
