    Script and custom tool work together ?
    6 Posts 3 Posters 554 Views 3 Watching
    • Didier BurD
      Didier Bur
      Is this possible ?
      1. Start a script execution
      2. Pause the script and launch a custom tool (such as a "getpoint" tool for instance and return the clicked Point3D)
      3. Resume the main script and use the Point3D variable.
      #start script
      point=Sketchup.active_model.select_tool MyGetPointTool.new
      # resume script
      The problem is that if it is not possible, one has to encapsulate all the script in the tool itself.
      Any hint someone ❓
      DB
      • thomthomT
        Pretty sure you can't pause it.
        You don't have to encapsulate the entire script into the Tool class, just make the Tool's deactivate event trigger your main script again.
        • Didier BurD
          Didier Bur
          Hi tt,
          Sorry, but how to do that ?
          def deactivate()
          DB
          • Chris FullmerC
            yeah, exactly.
            def deactivate my_script end
            Just have it call your script again when it de-activates. You could even set up your script to accep arguments so you can send in the point3d.
            Chris
            All my Plugins I've written
            • thomthomT
              Something like:
              module MyModule
                def some_method
                  # lalala
                  Sketchup.active_model.tools.push( MyTool.new )
                def continue(args)
                  # lalala
                class MyTool
                  # Collect data...
                  def deactivate
                    MyModule.continue(args)
              • Didier BurD
                Didier Bur
                Cool, thanks a million 😍
                DB
