    Script and custom tool work together ?
    6 Posts 3 Posters 352 Views 3 Watching
    • Didier BurD Offline
      Didier Bur
      Is this possible ?
      1. Start a script execution
      2. Pause the script and launch a custom tool (such as a "getpoint" tool for instance and return the clicked Point3D)
      3. Resume the main script and use the Point3D variable.
      #start script
      point=Sketchup.active_model.select_tool MyGetPointTool.new
      # resume script
      The problem is that if it is not possible, one has to encapsulate all the script in the tool itself.
      Any hint someone ❓
      DB
        Pretty sure you can't pause it.
        You don't have to encapsulate the entire script into the Tool class, just make the Tool's deactivate event trigger your main script again.
          Didier Bur
          Hi tt,
          Sorry, but how to do that ?
          def deactivate()
          DB
          • Chris FullmerC Offline
            yeah, exactly.
            def deactivate my_script end
            Just have it call your script again when it de-activates. You could even set up your script to accep arguments so you can send in the point3d.
              Something like:
              module MyModule
                def some_method
                  # lalala
                  Sketchup.active_model.tools.push( MyTool.new )
                def continue(args)
                  # lalala
                class MyTool
                  # Collect data...
                  def deactivate
                    MyModule.continue(args)
                Didier Bur
                Cool, thanks a million 😍
                DB
