    Noncoplanar faces in a imported model, how can I clean it?
    4 Posts 3 Posters 606 Views 3 Watching
    • S
      Sycristian
      I have problems trying to clean a 3ds format 3d model in Sketchup. I realized there are a cleaning up plugin written by Thomas Thomassen, I tried out that plugin in that model but the result weren't as good as I expected.
      http://img25.imageshack.us/img25/3668/probps.jpg
      The clean up plugin did great in some parts of the model skipping some lines but in some parts it could't, after that I turned the original model bigger and tried again the clean up plugin but the result was the same.
      I tried out the application MeshLab but I couldn't find any filter that resolve my problem.
      Here is another view of the model.
      http://img34.imageshack.us/img34/6596/prob2b.jpg
      What should I make a imported model cleaner?
      • D
        d12dozr
        It looks like you just need to smooth the remaining lines...select the raw geometry, then right click -> Smooth... and adjust the slider until it looks good.
        http://goo.gl/f7ooYh
        • GaieusG
          The plugin (or in fact even a manual cleanup by deleting edges) can only delete edges between coplanar faces - without losing those faces.
          It seems that the remaining faces (after cleaning up) are not coplanar. This can of course worked around by smoothing those surfaces like Marcus suggested but also make it harder to texture and work with.
          • S
            Sycristian
            Excellent, thanks for the fast responses, I am a beginner in sketchup modelling, I apreciate a lot your help and share your experience with me.
            Thanks d12dozr, Soften and Smooth it's a great tool that makes the models look better hiding its lines, thanks, my model looks better now.
            Thanks Gaieus, after using Soften and Smooth tool on the models raw I realized that the lines and noncoplanar faces still remain there. The main problem of the model is the high number of noncoplanar faces because that faces make difficult to modify the model, the model have a large amount of faces, therefore, if it's used in a larger model can reduce the performance of Sketchup.
            It looks like the only solution is intersect the model and delete the lines manually or delete the lines of the noncoplanar faces and redraw those to make a coplanar face.
            Thanks for your help
