    Adding dynamic attributes to multiple objects
    19 Posts 4 Posters 1.9k Views 4 Watching
    • N
      NewGuy
      Is there a way to add attributes to a group's "dynamic_attributes" dictionary? I am try this concept below:
      selection[0].attribute_dictionary("dynamic_attributes").keys.push "attributename"
      I am trying to do this because I want to add the same attribute and sometimes the same value to multiple groups and the component attributes interface only lets you do one object at a time.
      Thanks,
      NewGuy
      • thomthomT
        You want to add an attribute to all instances of a definition?
        Then you can add the attribute to the definition instead of the instances. Just make sure to remember to check the definition whenever you access it.
        • N
          NewGuy
          I think set_attribute is what I was looking for.
          • N
            NewGuy
            Is there a way to toggle the attribute so that "Users can edit as a textbox" in the Component Attributes panel?
            • J
              Jim
              That's all controlled by specially named attributes in the "dynamic_attributes" dictionary. If you have Pro, you can edit them in the Attributes Editor, so I'm assuming you are using the Free version?
              • J
                Jim
                Here is a DC with a single editable Textbox for an attribute named Color. Maybe it'll help
                lemon_box.skp
                • N
                  NewGuy
                  I am using Pro but I am more interested in mass dumping attributes to objects that users using Pro can see. I am able to add the attributes using set_attribute but they show up as "User cannot see this attribute". How can I add an attribute so a user can see it or edit it?
                  Thanks,
                  • J
                    Jim
                    You need to inspect the "dynamic_attributes" dictionary. It uses meta-attributes that begin with an underscore to store meta-data about other attributes, such as if it has an entry in the Options dialog.
                    So for the model I attached previously, there is an attribute named "color", but also several that begin with "_color". These are what control how it appears in the Options dialog. I don't know the details of what all the meta-attributes are or do. You probably will need to reverse engineer them.
                    • J
                      Jim
                      So I was able to add a "Quantity" textbox to the user options dialog with the following code:
                      ad = selection[0].definition.attribute_dictionaries["dynamic_attributes"]
                      ad["quantity"] = "1"
                      ad["_quantity_access"] = "TEXTBOX"
                      ad["_quantity_formlabel"] =  "Quantity"
                      • thomthomT
                        Didn't realise one could set attributes like that.
                        • J
                          Jim
                          Yeah, it wouldn't actually be too hard to create a DC editor for non-pro users.
                          I was considering doing a specialized one just for animating doors and windows.
                          • thomthomT
                            I meant the way you added items to AttributeDictionaries. I've always used the explicit set_attribute method.
                            • J
                              Jim
                              set_attribute and get_attribute are probably better to use in the long run, if changes were ever made internally they would likely still work.
                              • thomthomT
                                heeeey? where was that comment of being able to remove attributs using set_attribute? mind trixies!
                                • J
                                  Jim
                                  It was wrong! I was thinking of something else. There was what I thought an odd way to delete an attribute, but I think it was an odd way to delete the entire dictionary.
                                  • thomthomT
                                    set_attribute can potentially kill the whole dictionary??
                                    • J
                                      Jim
                                      Ok, this is what I was remembering:
                                      delete_attribute can delete the entire dictionary if the value param is not used.
                                      http://code.google.com/apis/sketchup/docs/ourdoc/entity.html#delete_attribute
                                      Entity.delete_attributeSketchUp 6.0+
                                      The delete_attribute method is used to delete an attribute from an entity.
                                      If only the dictionary_name is given, then it deletes the entire AttributeDictionary. Otherwise, delete_attribute deletes the attribute with the given key from the given dictionary.
                                      • Dan RathbunD
                                        Dan Rathbun
                                        Entity.delete_attribute can delete the entire dictionary if the value param is not used.
                                        AGREED !
                                        There should have been (should be,) an explicit Entity.delete_dictionary method (even if it calls the other one with 'secret' parameters. Of course the safest way is to rename and then override the delete_attribute method, so only a call to a delete_dictionary method would do the deletion.
                                        Which may actually be how things work with delete_attribute, ie if num args == 1 then it calls the Entity.attribute_dictionaries.delete(arg) method. )
                                        I'm not here much anymore.
                                        • N
                                          NewGuy
                                          Guys,
                                          Thanks for your help! Great insight.
