    Having trouble creating multiple windows
    5 Posts 2 Posters 636 Views 2 Watching
    • C
      comatose
      Hi, can anyone help me with creating and placing windows that cut holes in the wall where they're placed.
      here's what ive been doing- please correct me .
      i draw rectangle on surface of building
      then create component
      then divide into 3 and offset for frame
      i use the push tool to make my frame in relief
      then i add the glass texture to window and aluminium texture to frame
      close editing component
      then i select window, select move tool, hold down ctrl key and type in the distance for my next window on the green axis.
      the resulting window has no effect on the surface of the wall- even when i explode the component.
      what am i doing wrong- i have a lot of these windows to place.
      help appreciated!
      • GaieusG
        Hi comatose,
        Could you attach your window component?
        • C
          comatose
          @gaieus said:
          Hi comatose,
          ok, here is a section of the wall with some windows attached.
          thanks! πŸ˜„
          window-component.zip
          • GaieusG
            If you had purged the file, could have been about 5-600 Kb
            πŸ˜„
            Well, your component was not set to glue and cut opening first of all.
            Then it was just a little bit misaligned and the component axes NOT set correctly for cutting a hole. In order to cut a hole, a component must have a closed loop of edges (not necessarily with a face or with only one face) that will actually "cut" that hole. Making sure that the component axes are correctly set is the most crucial part of such components.
            The best and most fool-proof strategy is to first draw a rectangle, double click and immediately turn into a component. In this case SU makes it a gluing/cutting component by default and places the axes correctly (they cannot even be placed differently on a 2D entity).
            THEN edit your component and add the details.
            window-component.skp
            • C
              comatose
              πŸ˜„
              [attachment=1:1nr2cmpk]<!-- ia1 -->Comp.png<!-- ia1 -->[/attachment:1nr2cmpk]
              Thanks heaps for correcting my model and for the advice. i originally created the whole model from autocad layers that were a bit messy. i made the whole model again from scratch to make sure all the faces were aligned.
              cheers! πŸ˜„
