    How to retrieve an observer attached to an entity ?
    11 Posts 5 Posters 1.0k Views 5 Watching
    • Didier BurD
      Didier Bur
      Hi all,
      Everything is in the title.
      Entity.get_observers documentation is empty and I get an error when playing with it:
      Sketchup.active_model.selection[0].get_observers
      select an entity and get: undefined method `get_observers' for #Sketchup::Edge:0xe259650
      Anyone has used get_observers so far ?
      DB
      • J
        Jim
        I don't know where get_observers is being defined - possibly it is part of Dynamic Components and meant to be used on them. The method is not mentioned in the API documentation. (But this is just my guess.)
        If you need to remove an Observer after attaching it, the only way is to assign it a variable which will persist until you need it.
        @my_observer = MyObserver.new
        some_object.add_observer(@my_observer)
        # ... Later...
        some_object.remove_observer(@my_observer)
        • Chris FullmerC
          That is odd, I swear I saw that on the docs, but now as I'm looking, I can't find anything on it.
          Chris
          All my Plugins I've written
          • Didier BurD
            Didier Bur
            See the doc about it:
            http://download.sketchup.com/OnlineDoc/gsu6_ruby/Docs/ruby-entity.html#get_observers 😲
            My aim is to code a script for "sticky guides" (or lock/unlock guides. It works almost OK but I cannot unlock locked guides without retrieving the observers attached to such guides.
            The locked guides "resist" to the eraser tool (they are not erased) but are erased when using the "Edit/Erase all guides" menu. That's because when deleting more than one entity at once, the observers seem not to trigger.
            DB
            • J
              Jim
              The most recent and accurate documentation is here:
              Error 404 (Not Found)!!1
              (code.google.com)
              • Didier BurD
                Didier Bur
                Thanks Jim,
                As you can see, get_observers has disappeared from the doc between su6 and 7 πŸŽ‰
                DB
                • thomthomT
                  hm... does sound like an internal method. But now that we know it has been partially documented I'd like to know the full story. πŸ€“
                  • R
                    RickW
                    If I remember correctly, .get_observers made a very brief appearance (perhaps beta 6 only?), and was removed due to a high chance of crashing SU. The method description lived on in the documentation, though, causing confusion even today.
                    RickW
                    www.smustard.com
                    • Didier BurD
                      Didier Bur
                      Hi Rick
                      The weird thing is that observers are almost unusable if one can't retrieve them to remove them. Keeping their reference via a variable is difficult because the add_observer method returns true or false, and not the observer itself. πŸ˜’
                      DB
                      • thomthomT
                        @didier bur said:
                        Hi Rick
                        If you look at Jim's example you see that he keeps a reference to the Observer instance he attaches.
                        • Didier BurD
                          Didier Bur
                          Me stupid 😳
                          DB
