    [REQ] sun plugin
    2 Posts 2 Posters 636 Views 2 Watching
    • soloS
      solo
      I know there have been a lot of sun path ruby's requested lately, however I would like something even simpler if possible, I'd like a plugin that I can click in a random place in the sky to place sun.
      The reason for this is when I am rendering with an hdri/ibl I can place the sun in the spot I need it in order to correspond with the hdri.
      Unless, there is another voodoo technique for doing this in Thea that is.
      (I want to use sun with hdri)
      http://www.solos-art.com
      • thomthomT
        What would be even more interesting would be to import a preview texture of the environment map as an environment sphere in SU and use that as a gizmo to extract the rotation you need to position as you want in your render. Then click on the sun position.
