    RPC 3D Trees
    4 Posts 2 Posters 1.9k Views 2 Watching
      diesellam
      Is there a way you can import the RPC 3d trees or people?
      • numbthumbN Offline
        numbthumb
        I don´t know if you can load the RPC content into SU directly, but there are RPC plugins for different apps like Auto CAD, 3dsMax...
        Revit can import RPC content AFAIK.
        Comfortably numb...
          diesellam
          So the alternative solution is to import the RPC trees into Revit, then export it to SketchUp from Revit? If so, what's the preferred file format for exporting?
            numbthumb
            You can export it from Revit as a .dwg file - however, if you are running a free version of SU7, you should download this optional plugin first http://sketchup.google.com/support/bin/answer.py?hl=en&answer=161784 to enable dxf/dwg import in SU.
            Check out this tutorial also http://forums.sketchucation.com/viewtopic.php?f=18&t=3271&p=236965&hilit=revit+sketchup#p236965
            Comfortably numb...
