    Searching for Plugins to create holes through curved faces
    3 Posts 3 Posters 545 Views 3 Watching
    • I Offline
      italomuc
      HI,
      How are you?
      I am completly new here and I wanted to ask, since it is not possible to create directly a hole for example through a cylinder with the push/pull function, if there is a plugin that enables to create circular or diferent holes through curved faces. Usually I intersect a smaller cylinder (representing the hole) with the Body-Cylinder and then I eliminate the surplus geometry, leaving the hole. But there must a quicker way, since I have seen impressive programmers here;)
      I would be very thankful!
      cheers,
      Federico
        There are a couple of plugins that let you do boolean operations on two sets of geometry.
        • numbthumbN Offline
          numbthumb
          Like this one http://www.smustard.com/script/BoolTools
          Comfortably numb...
