    Hello
    3 Posts 3 Posters 303 Views 3 Watching
    • I
      iratus
      I have a really easy question but i can not find the answer to it
      I have an old project with some 3d buildings inside. I would like to take some of this building export them (or copy) and use them to a new project.
      How this thing is possible ???
      Thank you in advance
      • D
        d12dozr
        Please see this recent thread for ideas: http://forums.sketchucation.com/viewtopic.php?f=79&t=28331
        http://goo.gl/f7ooYh
        • Jean LemireJ
          Jean Lemire
          Hi folks.
          Method 1
          1 - Open the model from which you want to use parts.
          2 - Copy the parts that you want to transfer in the new model (select then CTRL-C).
          3 - Open new model.
          4 - Paste and then move to proper place or paste in place to paste at the same geometrical ccordinates they where in the original model.
          Method 2:
          1 - Open new model.
          2 - Import the SKP file of the old model to bring it inside the existing model. It will come in as a component.
          3 - Edit the component and remove unwanted parts.
          4 - If required, explode the component.
          Method 3:
          1 - Load old model.
          2 - Save a copy of the using File Menu --> "Save as ..."
          3 - Draw the new stuff in this model.
          Just ideas.
